anybody use these speaker rings?
Old Jan 19, 2013 | 08:25 AM
B@man's Avatar
B@man
Default anybody use these speaker rings?
anyone have any experience with these speaker adapters?
http://www.ebay.com/itm/Harley-Davds...item5ae34dfc83
or should i pony up for the arc audio ones?
Old Jan 19, 2013 | 10:59 AM
0ldhippie's Avatar
0ldhippie
I'd be very Leary of those cheap molded Chinese plastic ones shaking around in the fairing. Dragonfly, Arc & Throttle up make quality pieces that won't fall apart.
Old Jan 19, 2013 | 12:10 PM
kitehog's Avatar
kitehog
I used these. They work fine. I wish the plastic was a little beefier so they would not flex, but once mounted they are solid. I also took a little dynamat type material and sealed the edges (Old trick I learned from my car stereo days) just to keep any rattle to a minimum and keep the air from escaping from the sides
Old Jan 19, 2013 | 08:08 PM
B@man's Avatar
B@man
im probably gunna try them out, not a huge expense either way
Old Jan 19, 2013 | 08:17 PM
gsxrboy96's Avatar
gsxrboy96
I just bought them, pretty nice for the money involved,
Old Jan 19, 2013 | 10:10 PM
voxer's Avatar
voxer
there good for the money.
Old Jan 19, 2013 | 10:18 PM
bent trix's Avatar
bent trix
I did see them when I was hunting for speaker stuff. I decided to use the solid ones provided by dragonfly only because the Rockford T3652s speakers have a huge magnet, and are heavy.
I don't see a problem using the less expensive rings, just be sure to use locktite if you use little nuts and bolts to mount the speakers to the rings.
Old Jan 19, 2013 | 10:20 PM
Classic bagger's Avatar
Classic bagger
Buy the Arc Audio. I tried those and returned them.
Old Jan 20, 2013 | 08:51 AM
rg567's Avatar
rg567
I used them. They are just fine. Maybe not a good looking a the arcs but they do the job. I would buy them again.
Old Jan 21, 2013 | 11:15 AM
Dragonfly2000's Avatar
Dragonfly2000
It all depends on the end result desired, I'm sure they will they hold aspeaker. Although doesn’t sound like a great mounting surface according to"kitehog"
The Dragonfly Rings, and the Arc (copied from Dragonfly) have a conicalshape which forces the sound through the hole. Putting a flat surface right infront of the speaker will create the sound waves in that area to bounce back,and cancel out the sound wave that is being produced.
They also don't look like they will allow you to use the speaker support bracket which is extremely critical.
With you HD forum discount the Dragonfly rings are 36.00
KDUBYA
Audio Systems
Apr 30, 2014 08:11 AM
DeneFXDWG
Audio Systems
Jan 12, 2014 05:41 PM
bkgabby
Sep 8, 2013 12:08 PM
wils5150
Mar 12, 2013 06:03 PM
pretz
Mar 5, 2010 11:38 AM
