Electra glide classic
Old Jan 20, 2013 | 09:46 PM
david foster's Avatar
david foster
5th Gear
Default Electra glide classic
Any ideas on why my fuel injected 07 wants to stall when stopped ? Starts right back up, but drops rpm's when stopping
Old Jan 20, 2013 | 10:13 PM
mkguitar's Avatar
mkguitar
any modifications ?
got lots of miles and maybe a clogged fuel filter ?
any codes ? ( like a bad crank position sensor )
welcome to the forums.
Mike
Old Jan 27, 2013 | 02:25 PM
david foster
5th Gear
no mods, 10,700 miles had codes checked ( bad crank position sensor ) reset code and no issues for 2 weeks. started same old crap again.
Old Jan 27, 2013 | 03:13 PM
Tinman265's Avatar
Tinman265
Pull it and clean it or replace it. Sensor has to have a 100% read or there will be problems. Crank sensors are known to cause many gremlins....
Old Jan 27, 2013 | 03:14 PM
soos's Avatar
soos
I know that with my '06 there was an injector problem where the bike would die. The MoCo swapped out the injectors. I think I had 8* injectors and the fix was a 25* injector.
Old Jan 27, 2013 | 04:28 PM
UltraNutZ's Avatar
UltraNutZ
yeah that was a recall.. had the same done to mine but I think that only pertained to early 06 models.
If it's only dieing at idle, I think I'd be looking inside the top of the throttle body (remove air cleaner and you'll see it) at the little hole there. Spray some carb cleaner or sensor cleaner up there while twisting the throttle back and forth until the fluid runs clear. Make sure to put a clean rag in the bottom of the throttle body to absorb the fluid.
Old Jan 27, 2013 | 04:41 PM
steelerdude1's Avatar
steelerdude1
Clean you IAC, Mine did the same thing, and a good shot of carb cleaner fixed me up.
Pull off your air cleaner, and inside the throttle body at the 12 o clock position, there is a hole. Get some carb cleaner and spray it good, you should spray it until the cleaner comes out clear. I got alot of black goop out of mine.
Hope this helps
Old Jan 27, 2013 | 07:21 PM
david foster
5th Gear
thanks for the information, I will try all suggestions. It's a on off problem. rode today and it acted up off and on. If I shut her off and she starts right back up and does good for a little while nad then back to the same old crap.
Old Jan 27, 2013 | 07:40 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
there is a older very long thread in here "07 idol issues",common causes,iac tps,tps adjuster screw(likes to back out),if you got a crank position sensor code thats were i would start.
Old Jan 28, 2013 | 05:19 AM
katobird's Avatar
katobird
Clean the Throttle body...
