Front end wiggles when no hands on bars
Old Jan 22, 2013 | 07:56 PM
T K Glider's Avatar
T K Glider
If you got a Harley front tire with some miles on it that may be your problem.
Old Jan 24, 2013 | 10:35 AM
Biker John's Avatar
Biker John
Originally Posted by bigdumbnoitall00
neck bearing would be the first thing,but just because a tire is new doesn't mean its round.u can balance a brick but it will shake if u try and roll it.
Ditto!
Old Jan 24, 2013 | 10:47 AM
Rammer's Avatar
Rammer
My 09 did the same thing and it was the neck bearings. Had them tightened and took care of the problem. Made a big difference
Old Jan 24, 2013 | 04:03 PM
Recycled's Avatar
Recycled
If you are standing on the seat when this happens, try putting a toe on the bars or avoid the tar snakes.
Seriously, check the head bearings and make sure they are well greased and properly tightened and if the problem persists or gets worse, you may need to replace them. Lightly holding onto the bars your arms become stabilizers even if you are not conscious of the effect. Some bikes you can ride for miles on end without any noticeable change riding hands free...others not no matter what you try.
Not a wise thing to do anyhow, other than temporarily for minor tasks that require two hands.
Old Jan 24, 2013 | 07:23 PM
snip0721's Avatar
snip0721
the "fall away method" is a sort of open ended method. i sure wish there was a torque to spec method. steve
Old Jan 24, 2013 | 07:58 PM
Bill03E's Avatar
Bill03E
You can't get a torque wrench on the adjustment nut , how would you measure it?
Old Jan 24, 2013 | 08:05 PM
snip0721's Avatar
snip0721
no...i understand. just wish it was possable. sure would take the guess out of the "fall away method". just saying its not very exact.... steve
Old Jan 25, 2013 | 02:56 AM
emwolb's Avatar
emwolb
i'd had no experience with roadglides, never even sat on one, but decided to buy a 2013 roadglide ultra a few months ago. the dealership rolled a demo 2013 RGU out for me to ride to help me make my decision. of course i let go of the handlebars like i used to do regularly on my 08 streetglide. headshake from about 20 to 40 mph. i asked them if that was common with roadglides and they told me that the roadglides require 4 lbs of pressure or weight on the handlebars. no biggie, as i don't regularly ride with both hands off the bars. so i buy the 2013, same issue. front end shake from about 20 to 40 mph. i place one or both hands on the grips, and no more shake. above 50, no shake at all with hands off the bars. i think the next time i'm at the dealership where i get work done on my bikes, i'll have them adjust my neck bearings properly.
Old Jan 26, 2013 | 07:35 AM
billnourse's Avatar
billnourse
Had the same issue with my Limited. Low speed shake and tendency to follow the snakes. Adjusted the head bearings and it all went away. On a straight, smooth road I can set the cruise and ride for a mile with hands off if I want to.
Bill
Old Jan 26, 2013 | 08:52 AM
vtwinbob's Avatar
vtwinbob
check out service bulletin m-1246, it covers what you'll need to do. and here is all the service bulletins for the 09 on this thread https://www.hdforums.com/forum/touri...ing-bikes.html
