Front end wiggles when no hands on bars
Old Jan 26, 2013 | 09:02 AM
  #31
circlenine's Avatar
circlenine
I had the same thing happen on my Yamaha Road Star... 34 MPH was the worst. To fix it, I simply sold it and bought my SG. Problem solved. For now.
Old Jan 26, 2013 | 09:15 AM
  #32
petewerner's Avatar
petewerner
Originally Posted by Bill03E
The fall away should be tighter on a road glide than a bat wing bike, the swing should be from pulling the left bar all the way back, let go and it should go just past center.
A friend has one , and that is what we did , and it worked perfect, and it has been that way for about 2 years now.
Exactly!! Less swing for a RoadGlide than other touring Harleys.
My mechanic is an HD tech and owns the same bike as I have, when I had him go into it, I told him extra tight, he told me shut up, his is also tighter than spec via the swing test!!! Since that day, no more wiggle, at decel around 42 mph...
I don't even recall any bad characteristics, rearing their ugly heads since then, I also did the 944UT shocks about the same time, the forks are my next area to try and improve.
As most have stated, the steering head shaft bearings are set too loose, it requires removal of inner fairing stuff to get to the actual nut, it is not the hex nut on top, but underneath is another nut with slots cut in it all the way around, in an RG it is deeper than the speedo/tach mount so if U do it yourself, get the maintenance manual from HD that shows the proceedure and pics if U can.
gblass1
Aug 2, 2019 12:40 AM
Diverrick
Sep 28, 2015 09:39 AM
Johns98roadglide
Jun 11, 2013 10:20 AM
blackswampbiker
Jun 14, 2011 09:34 PM
TOMMY M
Mar 22, 2011 06:32 PM
