Engine noise
Old Jan 24, 2013 | 02:45 PM
cmose's Avatar
cmose
Default Engine noise
Just recently did a rebuild on my bike after a cam bearing went out. Big Boyzs Heads, andrew 26 cams, already had 95" flat top pistons. Got bike together Sunday and it started right up and sounded great. Yesterday after bike warmed up started hearing a knock, so I checked the adjustable push rods and they seem fine. Today bike sounded fine until it warmed up and I hear a knocking noise and then a higher pitched noise. What should I check now? I also replaced the lifters, new cam bearings and cam tensioners.
Old Jan 24, 2013 | 04:37 PM
stupid_rope's Avatar
stupid_rope
did the cam bearing explode?
Old Jan 24, 2013 | 04:44 PM
mrfikser's Avatar
mrfikser
check the oil pressure..it should give you a good idea if something is failing...
Old Jan 24, 2013 | 05:00 PM
EasternSP's Avatar
EasternSP
Can you isolate where the knocking noise is coming from, i.e. low right side, upper right side, low left side, etc. A helpful means of isolating noise is to use a broom stick. Place one end against the cam chest and the other near your ear. You will be able to hear distinctive sounds this way. Touch different places on the engine to isolate sounds.
Old Jan 24, 2013 | 06:37 PM
cmose's Avatar
cmose
I was afraid to let it keep running. My thoughts is maybe a lifter or push rod. I just pulled the cam plate and everything looks fine. But one push rod looks to be adjusted out 1/2 longer than the rest.
Old Jan 24, 2013 | 06:44 PM
cmose's Avatar
cmose
To answer the other question, YES the outer cam bearing exploded, believe it or not I was 100 miles from home and ran it wide open home. The cage mainly came apart and stayed contained in the cam chest. VERY LUCKY I guess.
Old Jan 25, 2013 | 12:41 AM
stupid_rope
did you make sure no little pieces scored anything? just curious
Old Jan 25, 2013 | 05:24 AM
cmose's Avatar
cmose
What would have got scored? I put new lifters in, new push rods, new cam plate and new bearings. The cams looked perfect, so unsure of what could have got scored.
Old Jan 25, 2013 | 06:41 AM
FrankCaputo's Avatar
FrankCaputo
1/2 what? 1/2 flat? 1/2 inch? If that's the case, you may have adjusted all the travel out of the lifter. I'd readjust them from scratch. Also, everything I've read says to turn the bike over without ignition to allow the lifters to pump up before engine start.
The 38 and 55 minute locations on this video are helpful:
Another good video:
The knock you describe sounds like what I had when one of my lifters collapsed.
Did Big Boyz do a good job for you? Thinking of using them for a cylinder bore and head porting when I go to a 95.
Old Jan 25, 2013 | 04:01 PM
cmose's Avatar
cmose
Sorry it is approx 1/2" longer than the rest. Why would I not hear the noise at startup?
street bob 59
EVO
Aug 15, 2018 04:31 AM
harley#1
Apr 6, 2016 08:27 AM
lineman06
Engine Mechanical Topics
May 11, 2015 03:29 PM
Reindeer
36
May 6, 2015 11:59 PM
Jim B.
General Topics/Tech Tips
Jan 25, 2008 09:35 AM
