Brake job
Old Jan 25, 2013 | 11:52 AM
06Cummins's Avatar
06Cummins
Default Brake job
Ok I have tried to find the info using search but no luck. I'm going to rebuild my MC and clean up the calipers flush all fluids and install new brake pads. Now I have read about cleaning the caliper pistons seems easy enough. Only thing that has me stumped is I have read about using a good brake lubricant. What are y'all referring to as far as lubricant? Thanks for the help
Old Jan 25, 2013 | 03:15 PM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
There are many brands of brake lubricant. Use it when you do a brake job to put on the back of the pads to reduce noise, put it on the pins, where the brake pads sit and slide in the caliper etc to keep everything from corroding or rusting and binding up. Basically it just keeps all the moving parts... well, moving.
Old Jan 25, 2013 | 03:22 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Most auto stores carry the stuff to put on the pads to stop squeeling.
Spray silicone is good for lubing the pistons & seals
Disk brake grease is also good for all the pins & stuff... use lightly
A little anti seize for the caliper mounting bolts
Old Jan 25, 2013 | 03:31 PM
06Cummins's Avatar
06Cummins
Gotcha!! All the brake jobs I have done never once cleaned the pistons just replaced the caliper.
Whiskyjock
Jan 16, 2018 06:50 PM
jackietan
Jun 29, 2017 09:34 PM
giacomo56
Mar 14, 2016 07:40 AM
2wheels4ever
Wheels/Tires
Nov 12, 2013 10:34 AM
SunRa73
Sep 27, 2008 10:46 PM
