Ah ha moment.
Old Jan 25, 2013 | 03:34 PM
A Whole lotta Rosey's Avatar
A Whole lotta Rosey
Default Ah ha moment.
I am considering upgrading my cam. Did all of the reading, asked a lot of questions here and had decided on the cam for me based on my riding style.
Currently on '11 Limited 103, with stage 1 completed; ride 2up about 50% of the time, usually shift around 2500, like to cruise between 2500-3000rpm.
So my thinking was the SE255 "right"? Well I kept reading from you guys how you hate that cam b/c it dies around 4000rpm. I thought who cares, I don't ride in that range - but then it hit me. I'm in sixth going about 80mph/3000rpm and want to pass, right now she has a little left (but I want more in this situation - thus the new cam), so I twist on coming from 3000rpm w/ the 255 there's not much of anything left.
Is this why the 204, TW222 or Andrews 48 cams are better?
Old Jan 25, 2013 | 03:58 PM
grbrown's Avatar
grbrown
Talking
I will leave recommendations for a cam to others, but recommend you use more revs. Peak torque is around 4,000rpm and you will find your bike has a lot more giddy-up around there! In fact you will be fine up to 5,000rpm - well worth investigating.....
There a couple of HDF sponsors who are engine builders and would probably love the opportunity to help you really boost performance - perhaps porting heads, raised compression, serious cams - that will certainly do what you want.
Old Jan 25, 2013 | 03:59 PM
C.H.L.'s Avatar
C.H.L.
I have the 255 and like it. I don't feel it die at 4000, but maybe it does on a dyno, not sure. Never had it dyno'd, just use the map Jamie at FM gave me with my power vision.
I like low end torque. I typically don't pass people that are runnin 80 tho. That's my top freeway speed, I'm more typically setting the cruise at 75.
Hope that helps
Old Jan 25, 2013 | 04:18 PM
lionsm13's Avatar
lionsm13
SE 255's and Woods are the preferred cams for the herd(s).
However, there are many different grinds.
FYI; Cyclerama makes only one. period. The 575.
That's how sure they are of theirs.
American Bagger(latest edition) shows installaton of Feulng's new one, the 543(looks very promising)(Feuling stuff is very under-rated) which is between the 525 which I have and the 574, which is more of a mid range cam.
Had I not talked to Frank Drago and some guys in my area who have experience with the cam that I currently have, I probably would have went with the cyclerama 575 set. FWIW.
Old Jan 25, 2013 | 04:38 PM
0ldhippie's Avatar
0ldhippie
This is it! Any stock cam will run 80+ and few tourers run that hard but when ya want to pass that motorhome going 40-65 uphill in a narrow passing zone that isn't enough. While a 255 is better than the stock 96-103 cam there are so many better choices for a stock (stage 1) 103 like andrews 57h, woods 222 or even 555...
Old Jan 25, 2013 | 06:33 PM
mikelikesbikes's Avatar
mikelikesbikes
I would not say Fueling is underrated at all. Pretty pricey and IMO some of the best out there. I think less often mentioned may be a better way to put it.
Old Jan 25, 2013 | 06:52 PM
piasspj's Avatar
piasspj
Downshift
Old Jan 25, 2013 | 07:44 PM
Molarman's Avatar
Molarman
I also went with the Fueling 525. I have Rinehart duels and roland sands ac. Had the bike dynoed used TTS mastertune. 90HP and 103 Torque.
Old Jan 25, 2013 | 07:49 PM
av ultra's Avatar
av ultra
For a 96 imo the se 255s are a perfect cam, the 103 has a tad more comp, there's lots of cams better then the 255s for your bike.
Old Jan 25, 2013 | 08:04 PM
stupid_rope's Avatar
stupid_rope
any reason why you shift at 2500?
