New Bar Issue...
Old Jan 28, 2013 | 08:09 AM
scumBAGGER's Avatar
scumBAGGER
Default New Bar Issue...
Just put on new bars "wildone 575 bagger bar" and Hd grip "get a grip" http://www.latus-harley-davidson.com...FetDMgodXwIAHg
and i have a gap between the controls and where the bar gets bigger...have any of you seen this? is it the grip? I know that I have read on here that heated grips do that with this bar, thats why I went without heated.....it is the same size gap on both sides....
I know the pic wont help much as I did not get close but I post it anyways...
Old Jan 28, 2013 | 08:35 AM
davey019's Avatar
davey019
Yours is really noticeable. Mine was only maybe an 1/8 of an inch so very small and mine are harley grips also.
Old Jan 28, 2013 | 08:37 AM
jaysledge's Avatar
jaysledge
Are you talking about where the weld is? If so that is going to be normal unless you widen the holes in the controls (clutch & brake clamps) from 1" to whatever size bar that is 1.25-1.5". Then if the grips bottom out before you get them to the controls, you trim down the bars until everything fits. Or just do what I did and live with the gap.
Old Jan 28, 2013 | 08:52 AM
5TIME's Avatar
5TIME
Ooh boy-I have 578s ready to go, and my **** retentive self will not do well with any kind of gap. I have Willie G HD oversized (diameter) grips. The dealer will be installing mine, and I'm sure will give me grief about shortening if needed, or will charge me an arm and a leg. Not good. It it so much that a person would need to actually cut the ends, or within "grinding range"?
Old Jan 28, 2013 | 09:22 AM
stupid_rope's Avatar
stupid_rope
grinding would be easier to control the amount of material being taken off...you can always take more, but you cant add it back.
measure, mark with a sharpie and grind to that mark
Old Jan 28, 2013 | 11:07 AM
scumBAGGER's Avatar
scumBAGGER
wow really......
schmihj
2014-2024 Touring Models
Sep 5, 2017 09:57 AM
utlonghorns416
Nov 23, 2012 06:42 PM
bobros
Dec 7, 2008 08:06 PM
wvtommy
Jun 10, 2006 12:22 PM
pococj
General Topics/Tech Tips
Mar 17, 2005 11:15 PM
