Another li'l somethin' ...
Old Mar 16, 2005 | 11:51 PM
pococj's Avatar
pococj
Default Another li'l somethin' ...
about hand grips. If you have problems with grips stayin' in place, pull 'em off. Take a file and file several sharp but shallow grooves across the grip area of the bar. Mix up some epoxy glue, put it on the bar, and slide the grip back on. Clean the excess, and let it cure. They won't come off!
Old Mar 17, 2005 | 11:53 AM
billnourse's Avatar
billnourse
Default RE: Another li'l somethin' ...
I find that HD grip glue works okay, and they are still removable should you want to. I would think with your method they would be pretty premanent.
Regards,
Bill
Old Mar 17, 2005 | 03:40 PM
12Stones's Avatar
12Stones
How would you get those off Skip if you wanted to?
Old Mar 17, 2005 | 03:45 PM
Ironhead's Avatar
Ironhead
Stones... that's in the next thread. I think it calls for a B.F.H? [sm=lol.gif]
Old Mar 17, 2005 | 07:41 PM
pococj's Avatar
pococj
ORIGINAL: 12Stones
I slipped a screwdriver underneath them and worked it around. I run basically stock grips. Right now I have a NOS grips, left from the '70s, and throttle from the '50s. The throttle grip will rot out from UV by end of summer and I'll replace it with an early '70s grip for an internal throttle. They'll probably last as long as I have the bike.
Never seen any aftermarket grips that struck my fancy. Most of 'em now are chrome-crap, and not worth having if you ride frequently, especially in good ol' hot Texas weather. The sweat from your hands eats the chrome, and when it's 115 in the shade the last thing you wanna grab is a metal grip! [sm=icon_flaming.gif]
I've run some old style Anderson grips, but they weren't that comfortable. Also had some of those cushioned grips, but they didn't last long before starting to flake apart. Stock grips last, and are comfortable enough. I s'pose if I was wanting heated grips I'd change.
Old Mar 17, 2005 | 11:15 PM
hawk's Avatar
hawk
That HD glue does work well
ORIGINAL: billnourse
Regards,
Bill
larry harding
Jul 18, 2016 07:04 PM
larry harding
Aug 1, 2014 08:13 AM
randy98ss
Sep 1, 2013 09:59 PM
knights
Aug 28, 2012 04:06 PM
cannedham1
Mar 30, 2010 07:55 AM
