Can someone tell me how this connects from stock flhx? Do you cut at the green connector and splice or what? I'm runnin into issues with my throttle now as I cut out the green connector and just soldered the wires. So I may need to go back and add the screamin eagle extension.
Here wiring if just cut out green plug and solder & shrink wrap keeping original TBW sensor.
HD has split the wires coming from the sensor into two group with two different color shrink wraps:Black and Yellow. I will now refer to these as Black side wires and yellow side wires. Each side has a white wire, black wire, and red wire. This is what it looks like:
Here is how the wires will hook up.
