Stator question
Old Feb 4, 2013 | 02:48 PM
Drilln'Boss's Avatar
Drilln'Boss
Default Stator question
I just got my motor back from the shop and got it installed. I installed the stator then the rotor. When I turn the rotor I can hear what sounds like the magnets hitting the stator. Is this normal? Same stator, same rotor, same motor. Took the rotor off and turned the motor, no noise.
Old Feb 4, 2013 | 03:03 PM
twincam47's Avatar
twincam47
On late models there is a spacer that goes on the crankshaft before the rotor goes on.
PN# 24009-06
Old Feb 4, 2013 | 03:30 PM
Drilln'Boss
Thanks for reply. The spacer is on the shaft.
Old Feb 4, 2013 | 03:57 PM
Drilln'Boss
I had a timken bearing installed, could that have an effect on the spacer depth?
Old Feb 4, 2013 | 04:21 PM
Drilln'Boss
Okay, I think I got it figured out. I pressed on the top of the rotor while I turned the crankshaft and no noise. I'll put everything together and tighten it down and see what happens.
Anyone is still welcome to throw their .
Old Feb 4, 2013 | 08:35 PM
twincam47's Avatar
twincam47
I thought you were tightened up?????? So if the compensator wasn't torqued up then the magnets in the rotor could pull to one side or the other and rub. The rotor wont run true till its torqued up.
I think you figured it out yourself. Let us know.
Old Feb 4, 2013 | 08:40 PM
Drilln'Boss
Yep, it's all good.
Bullys FLSTN
EVO
23
Oct 5, 2024 11:55 AM
Yankee Dog
EVO
Jul 4, 2015 02:21 PM
Pinetop
EVO
Apr 28, 2014 08:10 AM
Harleyonthebrain
EVO
Jun 18, 2010 02:24 PM
wiseguyups
Aug 30, 2009 07:40 PM
