Differnace in Stator Rotors
Old Jul 15, 2012 | 10:09 AM
Bullys FLSTN's Avatar
Bullys FLSTN
Default Differnace in Stator Rotors
Ok, you all helped me determine my stator is bad (In a state of Stator confusion). Next question is can you tell me the differance between the standard rotor and the heavy duty? I see that the heavy duty rotor does not come with the spacers. Does the thickness of the heavy duty rotor not require any spacers? Or would it be better to get a system with a standard thickness rotor? Also when installing the rotor how do you know if spacers are needed? Sorry to keep beating this horse but want to make sure i get this right the first time. Have found a Ultima system with the heavy duty rotor at a good price, and after comparing the different systems just got in a state of "stator confusion again. Thanks again for all the help. Bully
Old Jul 15, 2012 | 10:18 AM
Uncle G.'s Avatar
Uncle G.
If only the stator is bad, why are you replacing the rotor? I've had three stators on the bike, but I'm still running the original rotor.
Old Jul 15, 2012 | 10:31 AM
Bullys FLSTN
Good question G. Most everyone says to replace the whole system. Also don't know if the regulator is bad as well, so just figured on a complete system.
Old Jul 15, 2012 | 10:41 AM
grbrown's Avatar
grbrown
Talking
I have a later spec high output stator, but original 1990 rotor. I don't know of any merit in changing that. I have seen photos of one which started to break up, but that is rare. The rotor has no electrics, it is simply a handful of permanent magnets set into a casting, entirely inanimate! That is until it starts spinning and the stator gets all excited and generates electrickery.
Dr Hess has our definitive test process for checking charging. Hopefully he will be along soon.
Old Jul 15, 2012 | 10:50 AM
TwiZted Biker's Avatar
TwiZted Biker
Keep your old rotor it's much better quality than the cheesy replacements most kits have in them and yes you have do all kind of shimming and aligning with those at your own cost for the shims .
I've heard arguments both ways but from personal experience upgrading old bikes I've never seen or managed to measure a difference in out put or life span between them .
Old Jul 15, 2012 | 04:11 PM
insp.clouseau's Avatar
insp.clouseau
Hehe, I came to the exact same point with my bike.
So if you're bike isn't loaded with electric junk...do you get any benefits with replacing with a "high output" stator?...they usually are 'high priced" too...
And again...how do you know if you need spacers?
If you use Moco parts, is there any chance it's a plug and play situation?
Guess I'm in the same situation as Bully...
Old Jul 15, 2012 | 04:16 PM
Stiggy's Avatar
Stiggy
I replaced no less than 2 stators on my bike in the first 32,000 miles. Then when I lost the third at 57,000, I went with the newer "3 Phase" systems available from CompuFire and ( I believe,) Cycle Electric.
Now at 112,000 mles almost 3 years later and the system seems bulletproof. $400 complete from my Indy.
Old Jul 15, 2012 | 04:29 PM
TwiZted Biker
Look at the spline area where the rotor goes on the shaft , compare how thick the stock on is verses the new replacement unit which are about 2.5mm , the difference is what you have to shim up to get the compensating sprocket alignment right so the primary chain runs straight and the new ones tend to wobble out the splines just not meat on them . Also why they market the " New " heavy duty one for $$$$$ , you get to pay for somebody else not so bright idea .
Going the bigger 32 amp stator does 2 things , better for the bike & battery and means you can get one anywhere if it fails no waiting to order one from who knows where .
Old Jul 15, 2012 | 04:38 PM
Spanners39's Avatar
Spanners39
Originally Posted by Bullys FLSTN
Most everyone says to replace the whole system. .
That is because "most everyone" isn't a proper mechanic and is talking BS....fix the rotor, check the output, if its fine its fine......never actually had to replace a regulator after a bad stator....people make things up because they think that one thing always leads to another when in reality it doesn't.
Regulators can die of their own accord but when a stator goes it usually stops giving any power to the regulator and therefore the regulator isn't doing any work and idelness won't kill it.
A massive spike in output can kill a regulator as it can't dump the heat produced by regulating quick enough but in my experience a fried stator doesn't produce a power spike...a dead regulator can and will do that though.
No doubt the two can fail together but its a myth to say that they should or must be replaced together.....save your money for cheap hookers and expensive Tequila.....
Old Jul 15, 2012 | 04:46 PM
TwiZted Biker
I think the replace both thing came about during the shovel years when the MoCo changed the charging system 3 times with a different plug configuration and nobody ever had the right ones in stock so it was do both if you didn't want to sit for weeks waiting . Now it's pretty much standardized if it works leave it alone .
