Speaker cut out
Old Feb 4, 2013 | 08:38 PM
bo bob's Avatar
bo bob
Default Speaker cut out
Alright i have a 2005 FLHTCUI my front speakers are cutting/ not even working i took the fairing off and cleaned the connectors still doing it i am not sure whats wrong. Its a stock stereo not sure about the amp, but there is one. the speakers are all aftermarket i hooked the wiring to other speakers and still the same cutting out and not working!!
Old Feb 5, 2013 | 06:33 AM
bogieb's Avatar
bogieb
Are you by chance trying to listen to an MP3 player when the issue occurs? If so, it can be your connection to the MP3 player, or the cable itself is shot (I had my left speaker cutting out, then used the cable in the Jeep, go the same issue - got new cable and all is good). If it is happening all the time, I got no clue.
Old Feb 5, 2013 | 07:11 AM
santajim's Avatar
santajim
Are you sure it's the speakers or the stereo itself. Mine was doing the same thing and it turned out to be the head unit.
Old Feb 5, 2013 | 07:19 AM
ratdoc's Avatar
ratdoc
Sounds like you've eliminated the speakers as the problem. Try bypassing the amp to see if it's that or the HU.
Old Feb 5, 2013 | 07:28 AM
flhrbill's Avatar
flhrbill
Had the same problem this weekend. I have the Hogtune amp and speakers, have been installed about two years. The left speaker was cutting out. Took the fairing off and cleaned the connections where the power supply is. In this case the power supplied for the speakers came from the cig lighter. Once I attached the wires the speakers didn't work at all. Problem at this point was a blown fuse. If the speakers are not working at all, check the fuse for the power supply. Doubt it is caused by the amp.
Old Feb 5, 2013 | 10:40 AM
bo bob's Avatar
bo bob
Alright next time i am able to take the fairing apart ill try all of these see if it works thanks guys for the help
Old Feb 5, 2013 | 10:50 AM
ratdoc's Avatar
ratdoc
Be sure to let us know how it turns out. These problems are always interesting.
Old Feb 5, 2013 | 11:04 AM
popome's Avatar
popome
Correct ohm matching important as well as how speakers are wired to match amps stableness at that level of resistance ,parallel , series or series parallel. Ain't no expert but impedance matching vital.
Old Feb 5, 2013 | 11:29 AM
Texas Fat Boy's Avatar
Texas Fat Boy
If you really want to talk to an expert talk to: http://www.ironcrossaudio.com/
They will fix your stock head unit if that's what it is.
My head unit went bad on my '08 and it was fixed under warranty,
but when my head unit went bad on my '09 it was out of warranty and Iron Cross fixed it.
Old Feb 5, 2013 | 02:32 PM
bo bob's Avatar
bo bob
Another weird thing.. Turned the bike to on or start either or turned up the radio moved the fader to the front and it worked just fine no cutting out. but while i ride they cut out not sure if this helps anyone trying to help me but its really weird on why it would do that maybe the amp is going bad? When i figure it out ill post on this thread.. Oh and do you think a voltage reader will help see if i am getting the correct amount of power to the front speakers?
