Bike not charging...any ideas?
Old Feb 5, 2013 | 02:33 PM
Lawdawg's Avatar
Lawdawg
Default Bike not charging...any ideas?
09' Ultra, on the way home the other day engine light and battery light came on, got it home and put on charger, next day light was off. Riding around again and both lights came on again. Took bike to mechanic said stator was bad, had it replaced.
Now the volt meter is reading 12 not 14 and drops to 10 regularly.
Any idea what to check now? Every time I put it on the charger it will charge. Maybe regulator?
Old Feb 5, 2013 | 02:37 PM
Tekman_1's Avatar
Tekman_1
2nd Gear
Had the same exact problem with my 98 Ultra. Had to replace the stator, and the battery. Do yourself a favor though. Get a battery at a local parts store. About half the price of a harley one.
Old Feb 5, 2013 | 02:39 PM
Lawdawg's Avatar
Lawdawg
Thanks I will give it a try.
Old Feb 5, 2013 | 03:21 PM
collin's Avatar
collin
You might want to check this if your battery load tests ok.
Great weather we're having isn't it?
http://www.ehow.com/how_6182452_chec...regulator.html
Old Feb 5, 2013 | 03:25 PM
The Old Man's Avatar
The Old Man
My 08 Glide has an intermittent check engine light. Voltage drops and the battery light comes on. Only for a few minutes though then the lights goes out and it starts charging again. Happens every couple of weeks. I am going to check the wires going to and from the voltage regulator. Wonder if I spilled some oil on it changing the oil. They plug in with rubber boots.
Old Feb 5, 2013 | 03:29 PM
Assegai's Avatar
Assegai
Connections need to be tight - don't overdo it!
Check the 3 phase plug going into the regulator from the stator.
The regulator is the likely culprit - the bad stator might have taken it out.
Old Feb 5, 2013 | 03:35 PM
PistonPuller's Avatar
PistonPuller
Original battery? I would have that checked. It may not be holding a charge which can happen to a battery after it has lost all of its charge.
Old Feb 5, 2013 | 05:19 PM
bronxbill's Avatar
bronxbill
Had the same thing happen to me on my Triglide; voltage regulator was gone.
Old Feb 5, 2013 | 05:28 PM
kennygsuperglide's Avatar
kennygsuperglide
i know in my old metric bikes, stator and regulator went hand in hand. never replaced one without needing the other.
GEORGEW
Aug 10, 2016 09:06 PM
Inky
Electrical/Lighting/Alarm
Aug 12, 2015 07:50 AM
kpb46
Dec 9, 2012 09:49 PM
Junior_co
Sep 27, 2012 09:26 AM
tekeum
Sep 23, 2009 04:42 AM
