Crank run out..
Old Feb 9, 2013 | 06:40 PM
  #31
NMNSG08's Avatar
NMNSG08
I am only saying that, that is what some indy and harley mechanics are telling me.
If it were me i would agree that ...i would do the crank work.
Old Feb 9, 2013 | 06:43 PM
  #32
soft 02's Avatar
soft 02
Sure if you got 2-3k id go for it!
Old Feb 9, 2013 | 07:26 PM
  #33
Egldr05's Avatar
Egldr05
Originally Posted by Egldr05
Anything over 3 thou and I'd be yanking the crank out regardless of gear or chain. I personally wouldn't run gears over .0015. but I'm kinda fussy, so far it's worked out pretty good for me (being fussy).
Rick
I should add I have good reason to be fussy. I put a 98" motor together with gear drive (.0015 runout) and below was the result after the crank slipped. It pretty much destroyed the motor. I put it back together with a DH crank and added the Timken bearings. I vowed from that day on to always build from the bottom up. That's one of the reasons I built my 120" instead of the crate motor.....peace of mind.
Rick
Old Feb 9, 2013 | 07:41 PM
  #34
piesik650's Avatar
piesik650
I should add I have good reason to be fussy. I put a 98" motor together with gear drive (.0015 runout) and below was the result after the crank slipped. It pretty much destroyed the motor. I put it back together with a DK crank and added the Timken bearings. I vowed from that day on to always build from the bottom up. That's one of the reasons I built my 120" instead of the crate motor.....peace of mind.
Rick
I completely agree. build the bottom end solid.
Old Feb 9, 2013 | 09:50 PM
  #35
JetD's Avatar
JetD
Default Forced Rebuild: Crank Runout Fault
Last two HDs cranks spun.... too much OEM runout was the stated reason.
Began both rebuilds (a 117" and a 107") with welded, trued, balanced cranks which really smoooothed the engine out -- noticeably.
A 'do it once' build begins with the foundation.... the crank.
YMMV, but, for me, it's the crank because HD no longer does the best OEM products... but they're not the only company that is run by bean-counters these days....
I will say that ESP pays off... if you ever spin a crank... both ESPs, for me, paid for themselves at least 4 times over...
OK, back to the OP subject...
Old Feb 10, 2013 | 08:05 AM
  #36
Lowcountry Joe's Avatar
Lowcountry Joe
Here's my 2010 measurement. I was curious so I bought the Fueling setup and measured it when I did the cam swap. A tad over .004 at 13,000 miles. I have an esp, but even if I didn't, I wouldn't lose any sleep.
Old Feb 10, 2013 | 09:11 AM
  #37
axlespacer's Avatar
axlespacer
All right can someone explain what an ESP is?
Old Feb 10, 2013 | 09:31 AM
  #38
stonesmith's Avatar
stonesmith
I sent a brand new OEM crank to Rev Performance for true and weld .the sheet that they sent back said this:
Original runout on pinion inner: 0.004
Original runout on sprocket inner:0.004
Original runout on pinion outer: 0.003
If these inspection numbers are legitimate, I'd have to say that they are not to impressive for a brand new factory crank on truing stand
Old Feb 10, 2013 | 09:34 AM
  #39
Lowcountry Joe
Extended Service Plan. This is extended warranty coverage that must be purchased before your original factory warranty expires if you want additional coverage down the road.
With all the mods I have make to my scooter, I am sure that I have screwed the pooch on mine!
Old Feb 10, 2013 | 09:38 AM
  #40
tbone108's Avatar
tbone108
Bean counting gits dont care about bkes only money
