Moving tour-pak back options
Old Feb 8, 2013 | 02:51 PM
Trial dog's Avatar
Trial dog
It is very easy and cheap to make your own. The last time I moved one I just drilled a couple holes and moved it back. My memory is that I could use two preexisting holes in the front and drilled two holes for the back. Cost was about 15 minutes of time.
Old Feb 8, 2013 | 03:29 PM
rleggs's Avatar
rleggs
2nd the George Anderson kit, quality American made product.
Old Feb 8, 2013 | 03:38 PM
Pumba11's Avatar
Pumba11
Originally Posted by CndUltra95
Thats cause the kurry guys tried to improve on Good Old Fashioned American ingenuity
Rob
Last time I checked Kuryaken is from Wisconsin...the same state where they make our bikes.
But I get your point. It can be overthought.
Old Feb 8, 2013 | 04:25 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
I used the George Anderson kit as well. If you want to remove it in the future the George Anderson kit will sale for you very quickly.
Old Feb 9, 2013 | 10:33 AM
Watchfuliz's Avatar
Watchfuliz
Drilled new holes.............15 minutes and free.
Old Feb 9, 2013 | 01:49 PM
TOM LILES's Avatar
TOM LILES
Stage III
I bought the kuryakyn tour-pak quick adjust relocator it's around 200.00 if i remember correctly.I have a companion tour-pak on a solo detachable bracket.I matched this with a mustang 17" solo/rider backrest.i can adjust the tour-pak to match the backrest and it's the best ride yet.if only I could figure out the shocks I need to cure a stiff *** ride. 2013 flhx.also front turn signal fill with water.
Old Feb 9, 2013 | 05:09 PM
Harsh1828's Avatar
Harsh1828
I wish some one made a kit that worked with the factory installed amp!
Old Feb 26, 2013 | 07:26 PM
CndUltra95's Avatar
CndUltra95
Thanks Pumba, was just trying to be a smartass.
The George Anderson kit ( do not have one )has served many well.
And the guy has a great reputation too.
Rob
Old Feb 27, 2013 | 05:42 AM
bundy43's Avatar
bundy43
George Anderson on a 12 ultra,good quality fast service,he usualy ships before he even gets the check
leadman
Apr 4, 2018 09:27 AM
sfcmo357
Jun 19, 2014 09:02 AM
chief1600
Jun 25, 2012 06:18 AM
avonflhtk
Apr 11, 2012 10:31 AM
Mr. Bill
Jun 18, 2010 08:36 PM
