speedo cable?
Old Feb 9, 2013 | 11:32 AM
lip's Avatar
lip
Default speedo cable?
does an 01 electra glide have a speedo cable? speedo went out replaced sensor. still not working?
Old Feb 9, 2013 | 01:38 PM
mkguitar's Avatar
mkguitar
The 01 has a speedo sensor in the top of the tranny ( the neutral switch is also mounted in the top of the tranny- it is bigger)- often the sensor gets clogged with steel filings from the gears wearing and removing & cleaning with a rag is all that's needed.
It is held in place with a single screw- usually an allen head
if you are sure the sensor is good, check wiring and the speedo itself.
the cable driven speedos were driven from the front wheel & were phased out by 1997 as I recall. The RK was the first to go electronic
Mike
Old Feb 9, 2013 | 04:27 PM
kyote's Avatar
kyote
I think '98 was the last yr for a cable
Old Feb 9, 2013 | 09:03 PM
Ultra89Rider's Avatar
Ultra89Rider
No, the Road King changed to electronic speedometer beginning with the 1997 model year.
The FLHT/FLT had the cable speedometer through the 2000 model year. Beginning with
the 2001 model year, all FL models had the electronic speedometer.
misfitJason
EVO
15
Nov 4, 2014 09:07 PM
HD4EVR
EVO
Feb 16, 2014 09:27 PM
Steve06FXDB
Dec 11, 2013 06:34 AM
janne63
EVO
Oct 3, 2007 01:23 PM
suprsnake
Jun 24, 2007 12:00 PM
