Converting late model touring to chain drive???
Unless I were to shred a front sprocket, I could repair chain malfunctions in about a half hour or less in the trailer.
The point of using readily available parts is very wise. When planning modifications, I try to do things in a way that in a pinch I could revert back to off the shelf stock parts to get home or complete a vacation. It doesn't always work out but for the most part I stick to it. The BDL belt primary I run causes me to keep spare parts on hand or risk sitting out a weekend or or getting trailered home.
When I was trying to figure out why the belt broke I was talking to an engineer at BDL. I was asking about what seemed like excessive slack in the belt and he said that was correct to have that much when cold to account for expansion of pulleys when hot. When drag racing at the strip there is no chance to get the drive line up to full temp but we hit the starting line and apply full power to a sticky track??? Made me really think about my choice and the engineering concepts behind a non adjustable belt primary.
I did have to replace my rear sprocket on the road once and ended up sleeping in the parking lot of a dealership for two days waiting on the part.
Otherwise I never had any issues and always chuckle when I read all the neg comments regarding chain drive conversions.
Just make sure to use a steel sprocket. Many are aluminium and aren't worth the powder to blow em up IMO.
I never really gave any care to the warranty.
People worry about the warranty but it is mostly useless. Things don't start breaking on a stock bike until after the warranty is expired. Either way there is a lot of misinformation out there regarding a voided warranty.
If your bike does foul up and need valid warranty work some dealers will look for any reason to tell you that you voided the warranty. Do not go on their word alone. Surprise surprise!!! Some dealers lie.
There is a federal law covering voided warranties. It states that the dealer is responsible for PROVING that the modifications made to the bike CAUSED the damage that is in question. Keys here are common sense an shopping for a dealer that is reputable and not just a move product type joint.
For example if I instal a chain drive on an otherwise stock bike, and my bikes computer takes a dump.....The warranty is not void.
It gets more interesting when you have a new bike that you toss on a full exhaust that has no catalytic converter, an intake and a tuner to run it......then your crank bearings go out. This, in my opinion, would still be warranty as the mods don't change power level anywhere near enough to tear up a bottom end. At this point a lawyer could probably get you that warranty work done but you would have to weigh the attorney cost against the cost of repairs.
I've heard some dealers tell people that you have to have all oil changes and services performed by them to keep warranty intact and that is a complete load of BS that is only there to get you back for an expensive service.
As you can see, voided warranties are a sore point for me because I HATE dealers that lie. If a dealer tells you that you will void your warranty, ASK AROUND. A dealer saying that you voided your warranty is not much different than me telling my girlfriend that my chin drive will only cost about $100. Lol
First, I had several items covered under the warranty so things do fail under warranty.
Second, having a warranty and getting your bike repaired under the warranty for warrant-able items is not a forgone conclusion. There are variances by state, additionally, if the item is a covered item, you still may have to go to court to get it fixed and even then you may end up sucking wind. I am fully aware of the laws involved and I have the documents to prove it, I just finished a year long battle with H-D, they thru numerous law firms at me. in the end, I won. this took money, time and as the mediator said toward the end, neither of you are going to come away with what you want, you'll both come away with compromise. He was right.
PS, Dealers Lie and so does MoCo.
