It happened to me....
Old Feb 15, 2013 | 06:51 AM
Terrabella's Avatar
Terrabella
Originally Posted by tincup64
+1
tin
I think it is this unit under the air cleaner. Am i correct???
Old Feb 15, 2013 | 06:56 AM
soft 02's Avatar
soft 02
On the left side of the throttle body opposite of where the throttle cables hook up to the throttle body.
Its that black elbow between the push rod covers and the air cleaner cover.
Old Feb 15, 2013 | 07:20 AM
ftworthcowboy's Avatar
ftworthcowboy
Thanks, thats good to know.
Old Feb 15, 2013 | 07:54 AM
Hornick's Avatar
Hornick
Originally Posted by 03dragonRK
Look at the bright side. When you get it back you can ride, or you could be here watching the snow falling thinking maybe in 6 weeks I can ride
Very True. Brighter days to come
Old Feb 15, 2013 | 09:38 AM
tincup64's Avatar
tincup64
thanks
Old Feb 15, 2013 | 10:02 AM
Mark5's Avatar
Mark5
Thank you.
Old Feb 15, 2013 | 02:27 PM
cayers's Avatar
cayers
Glad to hear that everything worked out okay with the family and the bike!
Old Feb 15, 2013 | 03:11 PM
rufasim's Avatar
rufasim
Okay, I feel like an idiot. What is a tps?
Old Feb 15, 2013 | 03:12 PM
soft 02's Avatar
soft 02
Throttle Position Sensor.
Old Feb 15, 2013 | 08:15 PM
alii1959's Avatar
alii1959
Yep, the TPS connector is on the left side of the throttle body. I am not sure about the newer models, with true fly-by-wire, but with the older cable actuated ones you, obviously, can disconnect the bugger and ride away. You may need to remove the air cleaner and all to do so. I have a cannondale multitool that I got for bicycle riding that had heads for all of the specialty fasteners used there. BTW, why in the world did Harley use so many different fasteners? Just to frustrate folks? Seems odd. The multi-tool even had an allen wrench large enough for that big honking bolt on the air cleaner cover.
The mechanic said that riding it without the TPS didn't hurt the engine at all. The only problem would be the fact that the "steps" that the ECM normally provides wouldn't be available. So, should there be a next time, I will not hesitate to disconnect.
They had to replace one of the breather bolts that jut out of the heads....dunno where that sucker went....the rest was warranty work. Total cost $67. Not bad, I think.
porkerrican
Mar 18, 2012 01:03 PM
ronster
Sep 10, 2007 07:54 PM
Kolni
Aug 22, 2007 09:23 AM
raindropfx
May 22, 2007 12:54 AM
joe v
Apr 17, 2007 12:21 AM
