Dakota ANT-200 Digital Antenna Help
Old Feb 14, 2013 | 08:30 PM
WB's Avatar
WB
Default Dakota ANT-200 Digital Antenna Help
I am installing a Dakota ANT-2000 antenna in my faring and the instructions call for the small black wire (in the pic)to be wired to a 12 volt switched power source. Can anyone tell me why this needs to be done and what is the best place to tie into.
Old Feb 14, 2013 | 08:48 PM
mattbee's Avatar
mattbee
I'm assuming the 12 volts must provide power to some type of signal amplifier within the antenna.
I would splice it into a power source that's controlled by the key switch, so when the key is on, it's on, and off when the key is off!
Good Luck!!
Old Feb 14, 2013 | 08:56 PM
Nute's Avatar
Nute
The reason to have it on a switched power source is so you battery doesn't get drained when the bike is not running. There is a switched power supply in your headlight wire nest. I seem to recall the wires are black and red. If memory serves me, one of the wires has a red plastic cap on it.
Old Feb 14, 2013 | 10:01 PM
WB's Avatar
WB
Thanks guys. I got my answer in the Audio Forum. It is an amp'ed antenna. Tapped into the cig lighter. This place is a wealth of info!!!!!!!
WB
Audio Systems
Feb 14, 2013 09:57 PM
HD_Matt
Mar 13, 2012 05:00 PM
JakobusErik
Jan 9, 2011 07:20 PM
GMC4EVR
Jul 12, 2008 06:55 PM
GREEN MACHINE
Jan 26, 2007 08:40 PM
