There are no cats in any HD set of headers. Simply not enough room. They are in a collector tube after the header tubes terminate just like in cages. Read the manuals. That is HD's term for them -Collector tube.-
First cat collector's other than Calif. was in the 10 touring. 10 Dyna's and Softails non Cali were in the mufflers and still are except for the Switch Back which has the collector tube.
If you see a heat shield on a muffler it is there because of the cat. The exception is the touring CVO's that have a heat shield on the muffler so one cannot see the ugly color the chrome turns to with the heat from the cat.
Cats seem to run away often. The muffler ones are the easiest to loose.
