Highway peg mount problem
Old Feb 26, 2013 | 01:15 PM
brschmidt's Avatar
brschmidt
Default Highway peg mount problem
Anybody know the trick to get the D washer in the peg slot withthe clevis bolt? I've installed highwaypegs/mounts before and don't remember having any issues but I can't wedge the Dwasher in with the peg bolt. Without theD washer the peg just flops around. Gotta be a trick? Help mostappreciated!
Old Feb 26, 2013 | 01:17 PM
Jinks's Avatar
Jinks
Put the washer in, then force the peg in on top. It's a spring washer to add tension. Once it's all lined up insert the bolt.
Old Feb 26, 2013 | 01:20 PM
Campy Roadie's Avatar
Campy Roadie
What jinks said. Washer first then wiggle the peg in and pin it.
Old Feb 26, 2013 | 01:27 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
I put the washer in as best I can...... then I use a series of allen wrenches going from small then getting bigger to align the washer and peg mount, until the bolt goes in.
Old Feb 26, 2013 | 02:42 PM
brschmidt's Avatar
brschmidt
Thanks for the replies. I was getting close to using the BFH.
Old Feb 26, 2013 | 02:54 PM
shooter5074
If you have a drift punch, it will work wonders.
Old Feb 26, 2013 | 03:38 PM
dyna07custom's Avatar
dyna07custom
+1 very easy with drift pin
Old Feb 26, 2013 | 03:59 PM
fj1200's Avatar
fj1200
liberal amounts of WD-40 and lots of profanity.
Old Feb 26, 2013 | 05:20 PM
jethro69's Avatar
jethro69
LOL
Old Feb 26, 2013 | 05:33 PM
brschmidt's Avatar
brschmidt
Finally got them both on. More of a PIA than it should be but... The other side went together fairly easy using the drift pin mentionedabove and a plastic hammer. Had to use the BFH just a bit on the side Istarted on first and it's really stiff to fold the peg. The amount of tribal knowledge and experienceon this forum is fantastic!!! Thanks
Kile
Sep 7, 2017 07:52 AM
FenderGuy53
May 29, 2014 10:43 PM
tincup64
Feb 21, 2013 08:30 PM
IrishRedneck86
Mar 18, 2012 08:31 PM
doxbike
Jun 20, 2009 08:34 AM
