Performance mod overlooked....exhaust gasket!
Old Mar 4, 2013 | 09:22 AM
ironjunkie's Avatar
ironjunkie
Default Performance mod overlooked....exhaust gasket!
I recently did a big bore, FMoto head install and wanted to get away from the factory fiber crush type exhaust gasket. I first tried the smaller SE ring crush type without success due to leakage. Wasn't aware of any other type so I went back the to larger OEM fiber crush type for that good seal. After a week of new motor break-in, I decided to take a look at the exhaust port to see if there was any restriction from this crush type gasket. Holy crap was I surprised to find THIS much crush effect obstructing the exhaust port! As you can see, the black area was restricting the port! I haven't seen or heard much about this topic so I did some research and found the perfect solution as you can see. A set of Copper Compression Rings from 'James Gaskets' for a messily $12 bucks! Tip? I used a little anti-seize on the ring to hold in place until pipe install. The copper ring will not crush into the port however, it isn't a 'press fit' (very close though) on the outer wall either. Great seal and more power!!
Attached Thumbnails Performance mod overlooked....exhaust gasket!-p1060433.jpg   Performance mod overlooked....exhaust gasket!-p1060430.jpg   Performance mod overlooked....exhaust gasket!-picture.jpg
Old Mar 4, 2013 | 09:51 AM
MOSTWANTED's Avatar
MOSTWANTED
Would the Compression Rings from 'James Gaskets' be made for this purpose or for another application and re-purposed for the exhaust? Can you explain what you mean by pressed fit?
Old Mar 4, 2013 | 10:49 AM
Def Mute's Avatar
Def Mute
He probably meant...
Compressed fit, meaning the gasket is compressed when the exhaust flange is tightened down...
A 'pressed fit' would mean that the part is pressed into place with some force using any number of different means. Like with a shop press, an arbor press, or just a nuts/bolts/washer press to use in place on the engine or part...
That copper ring reminds me of the copper washers used on the old british bikes. We would re-use them by re-annealing the copper. You'll be better off using new copper gaskets when disassembled again, but if you're interested here's a site that explains how to re-anneal copper washers/gaskets...
http://www.motoiq.com/magazine_artic...r-washers.aspx
After looking at the Genuine James gasket site, I found that the copper exhaust gasket is actually a crush washer. So I don't believe re-annealing is an option, since it may actually be hollow to allow the copper to conform in the space and present a better seal. Good read anyway, and very short, if you are interested...
BTW, that was a good catch ironjunkie! Restricting a port can defeat the purpose. Good tip for anyone, modified engine or not...
Old Mar 4, 2013 | 11:05 AM
drukanfu's Avatar
drukanfu
What is the I.D. measurement of the used Harley seal ? Would it be 1 3/4"
Old Mar 4, 2013 | 12:13 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Question, did you torque the flange nuts to HD specs?
Reason being, I installed some MGS Duals on my bike, torqued to specs, 2 heat cycles and re-torqued to specs. I had to remove the rear pipe and the HD stock gasket had not mushroomed out into the exhaust port.
The James Gasket's was a good find though and I will book mark for the future.
Old Mar 5, 2013 | 05:07 PM
ironjunkie's Avatar
ironjunkie
Torque- No torquing, just tight. The exhaust flange appears to be flush with the head.
Fit- The ring didn't fit tight to the outer wall of the port, requiring anti-seize to hold it in place until I got the pipe in place.
ID- The used fiber gasket measured 1 1/2" after crushing. I'm certain the copper ring will not crush into the port like that, if any. Hope this info helps!
Old Mar 5, 2013 | 06:40 PM
HDV-GLIDE's Avatar
HDV-GLIDE
That's why HD lists torque values in their service manuals...Just saying....Tight and the right torque for the nut/bolt could be way off.....
Those copper washers do look interesting. What site did you buy them from? Link maybe?
Old Mar 5, 2013 | 06:51 PM
Eshaw301's Avatar
Eshaw301
WOW!!! Your 107 build must be a monster motor in order for that small amount of restriction to cause a decrease in performance!! They must have used the "special" b-heads and the "custom race proven" big bore kit instead of the regular heads and regular big bore on your bike. Just sayin...
Old Mar 5, 2013 | 07:20 PM
bagman1's Avatar
bagman1
I have replaced dozens of sets of pipes and never had an issue with oem gaskets, Ive even reused the same ones a couple of times. I would venture to say it was an installation issue that caused it to fail, especially since you didnt use the book spec to torque the nuts.
Old Mar 5, 2013 | 07:32 PM
KCFLHRC's Avatar
KCFLHRC
