slip ons and tuning???
Old Mar 5, 2013 | 06:56 AM
Shotglass's Avatar
Shotglass
Default slip ons and tuning???
I have a 2013 flhtc, I have had a couple guys tell me that it has a closed loop fuel system, and that if I put slip ons on the bike I will not have to do anything else, any thoughts???
I am thinking about vance and hines turndowns..
Old Mar 5, 2013 | 07:01 AM
VTL nut's Avatar
VTL nut
It is closed loop when certain criteria is met. This is a small percentage of the time in the scheme of things.
You will be fine swapping pipes only for all intensive purposes. That is not that drastic of a change and the ECM will compensate. Most people will add pipes, a free flowing air cleaner, and then tune to get as far away from the lean condition the MoCo has them tuned to meet EPA clean burn criteria.
The latter also unleashes the power potential these horses have available.
Old Mar 5, 2013 | 07:03 AM
Kritur's Avatar
Kritur
I.m not sure about that but if you will get someone....To remove the catalyetic converter your bike will run freer and cooler...I wouldnt put the slip ons on untill I did that....
Old Mar 5, 2013 | 07:31 AM
UltraNutZ's Avatar
UltraNutZ
Remove that cat-restricted headpipe first then go to the slipons otherwise you're not going to gain anything other than a tonal change in sound. You have a couple of options there.
  • Remove your stock headpipe and store it, buy a headpipe with 12mm bungs for o2 sensors like the Fullsac xPipe or others
  • Take your stock headpipe off, cut open the crossover chamber, remove all that packing then have it welded back.
  • If you look on ebay there are a few people selling stock de-catted headpipes.
Old Mar 5, 2013 | 07:34 AM
Zooki1's Avatar
Zooki1
Originally Posted by UltraNutZ
Remove that cat restrcited headpipe first then go to the slipons otherwise you're not going to gain anything other than a tonal change in sound. You have a couple of options there.
Ive got a stk de-catted header for sale on here--contact me if you're interested
2kids3pets's Avatar
2kids3pets
Slip ons require nothing else to be done. put them on and enjoy
commander112
2014-2024 Touring Models
Apr 8, 2018 06:02 PM
lyork
51
Dec 7, 2016 10:26 AM
Sal0615
Exhaust System Topics
11
Feb 10, 2013 01:36 PM
vegasjoe
May 4, 2008 04:31 PM
jrudicel
Sep 14, 2007 11:38 AM
