Diamond in the rough!!! Saving a FLHPI
Thanks
Mike
but got the wires ran through the bars, ran and mounted all the new cables. and even managed to break something! but it wouldn't be a day of me working on a project if i didn't break a part.
was finishing up and went to put the clutch lever back into the housing. that new plastic pin that holds the cable into the lever was a little long to slide into the housing. so i pryed a little bit on the housing to spread it. gave some pressure and SNAP!!! the lower portion just busted off. got pretty pissed at myself but it happens. found a replacement on ebay for 20 bucks and it's on the way
little tutorial on how i did the wiring
first take a pic of your connector before pulling the pins. then use a tiny screw driver or something small to release the pin connectors and pull the wires free from the housing
cut your wires with a spacing in between. this stops from having a large bunch of your connections.
do yourself a favor and get one of these quick wire strippers. cost like 10 bucks and worth their weight in gold. one quick squeeze and you're done. also cut your extension wires and prep them. color doesn't matter, just match your wires back up one at a time
solder connection should look something like this. i like to heat the wires up a little with the soldering iron and then apply the solder. this lets it melt into the wires rather than coating the outside
little heat shrink and you're done. give it a good tug to make sure it's strong
double check your work and run it through the bars
you could easily wrap these exposed wires with loom, or tape. but i have a cover that goes over the handle bar clamp so it won't be seen. i'll just leave it alone
finished product
hand controls and new grips installed
also got my replacement foot controls in from a 2012 RK thanks to a forum member. this will help give the bike a modern look. mine look like crap anyways
also got the trans fluid filled and am ready to finish up the other maintenance items.
was pretty frustrated but got over it. tossed the back wheel in there and found the next problem. it's funny how you only find the threads that you want, not the ones you need.... sure a mu85 will fit fine in an older chassis. that's what i found while searching to confirm the 06 electra glide wheel would fit my 2000. other than some axle spacers it went right in. except that the drive belt rubs ever so slightly. some more searching shows that a guy makes the correct spacer which is hub centric to give it some more clearance. so 80 bucks for the calipers, another 70 for this damn spacer. at least it came with a new tire which is the only thing that justifies buying the spacer. and it's already balanced
when you sit on the bike and roll back and forth, you can feel the belt and confirm it touches. damn
but at least it's on the ground for now. will have to pull the wheel and space the drive pulley, but it's some form of progress i suppose
while he finished sanding the inner fairing i fixed the hack job wiring that was done in the front and put the nacelle and lights back on. also pulled the foot controls to finish coating the lower frame. will have a small write up for adapting the newer style brake pedal onto the older bikes. not too much work.
anyways, here's a sneak pic of his bike and the little bit of work i got done too
