Polk mm install
Old Mar 10, 2013 | 10:13 AM
D.L.ANDER's Avatar
D.L.ANDER
Default Polk mm install
Have spent hours reading everything on forum about stereo systems and want to thank all of you. I do have one final question. I am installing Polk MM651 in lowers and am wondering if I can leave out the seperate crossover if I don't use the tweeters. Will be very simple install if I simply use the 2 wires I have there now. Otherwise 4 new wires to lowers and locate crossovers in fairing.
P.S. I am another convert from RF 4 chan to SS 4.520 amp. Now I just need a sticker that says "SOUND BY ULTRANUTZ"
Old Mar 10, 2013 | 11:14 AM
Tinman265's Avatar
Tinman265
You could omit the crossover but you would not be getting the most out of your system. There would be signals ment for the tweeters going to the woofers. If it were mine I would mount the crossovers in the fairing and wire it up like it should.
Another option would be to use the Polk Audio MM651UM speakers because the unit is all inclusive. Crossovers are mounted to the speaker assembly, tweeters are mounted to the grill, and there is no tweeter stalk coming thru the woofer. This does change the mounting requirements so I do not know if it would work in the lower speaker boxes. They also might need a coat of paint to hide them a bit (they are silver) and they do not come apart.
0ldhippie's Avatar
0ldhippie
Yes ya can but why would ya want to? They are designed as a system to give the full range of frequencies. Leaving out the tweeters leaves out the highs! Ya should have gone with coax instead of components??
Old Mar 10, 2013 | 11:18 AM
Tinman265's Avatar
Tinman265
MM651's are coax but there is a crossover that goes with them. There are 2 sets of speaker connections on the speaker itself.
Old Mar 10, 2013 | 11:29 AM
D.L.ANDER's Avatar
D.L.ANDER
I have a pair of in your face tweeters on my fairing and am questioning the need for them in lowers. I think I will attach crossovers in fairing and simply omit tweeter wires to pods. Thanks for the responses
Rodney Walker
Audio Systems
Mar 17, 2019 12:31 PM
jjlw
Audio Systems
Feb 2, 2017 06:17 AM
danj67
Audio Systems
Jul 30, 2013 07:06 AM
Meist21
Audio Systems
May 9, 2013 06:21 AM
GasCan
Electrical/Lighting/Alarm
21
Jun 25, 2010 10:55 AM
