Best Oil Filter
Old Apr 8, 2014 | 09:45 AM
  #51
hattitude's Avatar
hattitude
Originally Posted by whyrzwaldo
Forget those Timken muffler bearings. I heard from a tipsy HD parts guy that there is a guy who works 3rd shift there who has a wife that once vacationed in Japan. So that really isn't a true american product. Besides they use a 6 micron spacing between bearing rollers and the MoCo will deny any warranty claims because it exceeds the 5 micron requirement.
HA!
Just as I suspected......!!!!
Old Apr 8, 2014 | 09:54 AM
  #52
MadIrish's Avatar
MadIrish
Guys, Kury is coming out with a hot new upgrade, an aerodynamic plasti-chrome oil filter cover, that will address these mileage issues even with the stock filter.
We all know that the knurls on the stock filter (especially the chrome one...black is faster) breaks up the laminar flow over the filter, increasing turbulence and causing mini-vortices that increase drag. These vortices also trap warmer air around the jugs causing higher engine temps and further oil degradation.
The Kury cover will work with all stock oil filters (only a slight mod with a Dremel is needed to use it with the K&N for even greater MPG with that filter) for an increase of .002% increase in MPG.
I need a recommendation on which double stick tape to use, though. I've used 3M for years on my old metric bikes, but my buddies tell me that I should only use Scotch on a Harley.
Also, if I coat it with synthetic oil or dino oil, will the air pass over it even more easily???
Old Apr 8, 2014 | 10:01 AM
  #53
Brewmany's Avatar
Brewmany
Originally Posted by MadIrish
.................but my buddies tell me that I should only use Scotch on a Harley.
Scotch, Bourbon, Canadian, IRISH, it's all good. Single malt scotch will of course give better mpg's than blended.
But from someone who goes by the name of MadIrish, you could also do worse than Two Gingers.
Old Apr 8, 2014 | 11:24 AM
  #54
rapid49's Avatar
rapid49
Amsoil is my first choice, Wix is my second.
Old Apr 8, 2014 | 03:50 PM
  #55
bklynbob's Avatar
bklynbob
Originally Posted by UltraNutZ
if all you changed was the oil filter and you're now not getting any blow-by into your intake, then that could very well be a bad thing. That oil has to go somewhere...
Actually it isn't going anywhere,I'm using virtually no oil between changes.......
Old Apr 8, 2014 | 04:09 PM
  #56
fourburgs's Avatar
fourburgs
I use the scavenger puck only. No filter. The weight savings gained me 4 hp. and 6 mpg increase.. I can show you the dyno sheet to back it up
Old May 14, 2014 | 08:34 AM
  #57
Uncle Freddie's Avatar
Uncle Freddie
5th Gear
I think 3M makes Scotch tape. As far as oil filters go, The XT-1F is the best
http://www.lunghd.com/Idiocy/XT-1F.htm
Old May 14, 2014 | 12:09 PM
  #58
stan60's Avatar
stan60
I'm running K&P Engineering oil filter. So far, so good.
http://www.kandpengineering.com/
Tanker2
2014-2024 Touring Models
28
Apr 20, 2018 11:06 AM
FOCI
Oil Archive (no new posts)
Jul 5, 2017 01:41 PM
BigBobbyD
Jul 13, 2012 05:17 PM
PLEIKU69
Jul 29, 2011 09:26 AM
hdxbones
May 26, 2008 08:01 PM
