Screaming eagle air cleaner
Old Mar 20, 2013 | 02:16 AM
green hd's Avatar
green hd
Default Screaming eagle air cleaner
My Ultra came with the Screaming Eagle air cleaner as part of the stage one the previous owner put on her. My question is, Do you clean the filter or replace it? It looks like a K&N filter to me.( It's not a big sucker or any thing fancy, just sits under the cover) If it is, I should be able to clean it, right? Thanks.
Old Mar 20, 2013 | 02:33 AM
txfxstrider's Avatar
txfxstrider
Just wash it and let it air dry. Do not oil it.
Old Mar 20, 2013 | 05:19 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
That's bizzare. They sell a K&N air filter in the screaming eagle kit, they sell K&N filter oil at the dealerships. But then they say not to apply the K&N filter oil to the K&N filter in the screaming eagle kit.
I didn't know Harley said that in their instructions, and oiled my K&N filter anyhow. Knowing how they work, I wouldn't run a K&N filter without oil. Without oil, it barely catches anything except big chunks of crud.
Many folk do over oil their K&N filter, which makes a mess in the intake. But it is a self correcting mistake.
Old Mar 20, 2013 | 02:59 PM
RPS1981's Avatar
RPS1981
You need to figure out if your air filter element is K & N or Harley-Davidson Screamin' Eagle. The H-D SE unit does NOT require oil. The K & N does.
Old Mar 20, 2013 | 03:32 PM
Arizona's Avatar
Arizona
The H-D filter is PAPER... Do NOT oil it, just clean it and let it air dry then re-install. I've cleaned mine 5 or 6 times before replacing it. Easy to do and saves you money.
Old Mar 21, 2013 | 11:37 AM
RPS1981's Avatar
RPS1981
Just to clarify...
There is the OEM Harley air fliter element, but there is also a round, Screamin' Eagle air filter element that works with the Screamin' Eagle Stage One backing plate. It looks just like the K & N and Fuel Moto air cleaners.
Both the OEM and the Screamin' Eagle Harley air filters are washable and NEITHER Harley air filter is supposed to be oiled.
Bluegoose95401
Oct 9, 2017 09:17 AM
03snake
Jul 6, 2015 05:20 PM
JoeN
Sep 5, 2013 08:13 AM
big cahuna
Exhaust System Topics
Sep 11, 2007 08:47 PM
CobraKid
Nov 13, 2005 10:10 PM
