quick disconnect shield on RG
Old Feb 14, 2007 | 04:15 PM
vailtl's Avatar
vailtl
Default quick disconnect shield on RG
I would like to use the tall shield in the winter
and the short on in the warmer months for the
RG.
Do you all think these would work for quick disconnect.
www.southco.com/product/class.aspx?cid=7517
then click on product literture at right.
Old Feb 14, 2007 | 04:22 PM
Sharknose's Avatar
Sharknose
Default RE: quick disconnect shield on RG
I'm not a mechanical engineer, but at first glance I don't see how you would get the fasteners tight enough to hold the shield rigid.
And since you're only going to change shields twice a year, why worry about quick disconnect? It's not THAT hard to change it out.
Old Feb 14, 2007 | 04:24 PM
PhilM's Avatar
PhilM
If you can find a reliable and clean way to attach the dzus spring clip on the inside, then it should be fine. You may need a small rubber washer between the sheild & outer fairing.
If you get it working, take lotas pics... I might be interested in that too.
Old Feb 14, 2007 | 04:26 PM
2011 Road Glide Ultra's Avatar
No, I don't think those are usuable in this application. It's a 5 minute job as is.
Old Feb 14, 2007 | 04:38 PM
ROLLNTIGER's Avatar
ROLLNTIGER
Do what I did. Chrome skull heads fastened to the well nuts. Don't need a screw driver to take em off just un thread. Got mine from JP Cycles. You can see em in my sig pic.
Old Feb 14, 2007 | 04:46 PM
vailtl's Avatar
vailtl
My set up does take a while longer to install.
I have the RG windshield trim.
Thats the chrome one out of the catalog o7.
And I have a Rifle tall shield. trust me it takes
longer than 5 min. Under the chrome trim are
special fasteners. I would eliinate these with the dzus
system. I think the dzus fastners would suck the
shield in tight enough.
Old Feb 14, 2007 | 04:48 PM
snoopy's Avatar
snoopy
I installed chrome trim around front of windshield I would not change windshields it was a bear. I road a RG with short shield looked good but got lots of air. I have a short shield for my RK it does fine.
XjldX
Jun 1, 2014 05:00 PM
Nick1
Aug 4, 2012 01:36 PM
longrideshields-1
Jan 7, 2012 01:29 AM
Duke of HD
Apr 18, 2010 04:50 PM
Red Hot Ultra
Feb 9, 2009 08:26 PM
