Lighting issues?!?!
Old Mar 21, 2013 | 04:36 PM
rooster521's Avatar
rooster521
Default Lighting issues?!?!
`99 Road King, left rear blinker intermitting, thought to be a corroded connection at bulb, then right brinker intermit, sometimes it would work and sometimes not, thought to be thumb switch as I can put pressure on it and it would sometimes work.
Then last night I head home and Ive no lights at all except for gauge? Replaced blown 15amp fuse and right rear run/turn light is staying on bright (brake mode).
Could the run/ turn module be defective? What else could it be??
Old Mar 21, 2013 | 04:43 PM
1st 96 ultra's Avatar
1st 96 ultra
just unplug the module and go back to stock and see if that fixs the problem , if not start checking plugs for corosion or bad ground
Old Mar 21, 2013 | 04:47 PM
Harsh1828's Avatar
Harsh1828
Look under the rear fender, had a friend that had that issue and the wire harness that runs under the rear fender had been rubbed by the rear tire and was intermittently shorting out.
Old Mar 21, 2013 | 04:53 PM
elfnyc's Avatar
elfnyc
sounds like a short to me
Old Mar 22, 2013 | 04:32 PM
rooster521's Avatar
rooster521
well... found the culprit.
Seems we were all right, there was a short, and it was in the module. Seems last time some genius (me) changed the seats, the wiring on the module got pinched, eventually wearing thru, shorting the module and blowing the fuse. Works great with no module, apparently I popped a diode in it? Thanks for the help fellas.
Old Mar 23, 2013 | 07:01 AM
1st 96 ultra
damm gremlins , glad ya found it , easy fix
Seal
Jul 19, 2016 07:01 PM
huntabucks103
Electrical/Lighting/Alarm
Mar 24, 2016 08:16 PM
BGNIGHTTRAIN
Mar 8, 2015 01:23 PM
jimartina
Jul 21, 2014 07:26 AM
PistonPuller
Feb 23, 2006 09:55 AM
