The Saga Continues... sputtering problem
Old May 7, 2013 | 11:14 PM
  #31
my67pnycar's Avatar
my67pnycar
I would choose the power commander over the download. Download is still EPA compliant.
Old May 8, 2013 | 05:13 AM
  #32
darkcustom48's Avatar
darkcustom48
http://www.vanceandhines.com/store/fuelpak/lcd-fuelpak/
You can get one of these for about $250 I installed mine and programmed it on all of 20 minutes. My bike rides like a dream. Smooth power all over the throttle in every gear.
Old Jun 4, 2013 | 05:44 PM
  #33
Moondogger's Avatar
Moondogger
Latest Update.
The bike has been at the dealer for a few weeks now. They needed to replace the ECM and had to wait for Extended Warranty to appraise the situation and approve the new ECM. I got a report about a week ago that they were still having problems with the bike and thought they had been sent a faulty ECM. They did some more searching... TURNS OUT that the wire to the MAP sensor was rubbing and would short out sporadically. They replaced both the wire and the MAP sensor to be safe. They say the bike is running great now.
I pick it up tomorrow.
-Alex
Old Jun 4, 2013 | 06:24 PM
  #34
Trucky911's Avatar
Trucky911
After all your trouble I hope this is fixed and you can enjoy trouble free riding, you deserve it....
Trucky911
Old Jun 4, 2013 | 06:42 PM
  #35
Moondogger's Avatar
Moondogger
Thanks, Trucky911. I miss riding the bike. Our motorcycles truly are an extension of ourselves.
-Alex
Old Jun 6, 2013 | 11:11 PM
  #36
Moondogger's Avatar
Moondogger
Well, like the title of this thread says... the saga continues.
I rode the bike today, it runs great, none of the problems I had before, no sputtering... but, about 20 min. into riding, both the check engine and battery light came on and stayed on.
I checked the codes and these two came up:
P0132 - Front Oxygen Sensor High
P0562 - Battery Voltage Low
I'm not sure about the first code, but I know the 2nd one has to do with the stator and regulator. The dealer replaced both the stator and regulator this last time the bike was there, so I'm stumped as to why it would throw this code.
Any ideas?
Old Jun 7, 2013 | 01:54 AM
  #37
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I guess its time to use the break-out box.
Old Jul 4, 2013 | 10:30 AM
  #38
Teebo75's Avatar
Teebo75
Stage III
Unhappy 04 Electra Glide sputtering when it gets hot
I have a 04 Electra Glide with a S&S 124 from Star Racing. My motorcycle sputters and backfires real bad when it heats up. It barely takes off at red lights when the sputtering starts. It seems to stop if i get on the gas but starts back up again. I've changed map sensor, throttle position sensor, CKP Sensor, changed plugs because the bike was running lean, and changed wires. It seems to run fine when the motor is cool. It ran ok when i initially changed the plugs but started right back. Very frustrated with this problem. Seems to be something simple, just can't figure out the problem and im tired of wasting my money on sensors. Please help if you have any knowledge on the problem im having. It will be greatly appreciated! Thanks!
Old Jul 4, 2013 | 11:34 AM
  #39
bigskyroadglide's Avatar
bigskyroadglide
i just finished reading your entire thread, the only advice i can offer, if you can afford it, now is the time to trade. You have invested a lot of time and been diligent in trying to find the problem. Sometimes you have to just cut your losses and move on. This is one of those times. I am truly sorry no one has been able to fix the problem, but i rather ride than continue to deal with this type of issue. Being in CA, if you enounter this issue in high speed traffic, it is a safety issue, trade, move on and be happy.
Old Jul 4, 2013 | 11:46 AM
  #40
BrownSanta's Avatar
BrownSanta
just started having this problem as well and only once the motor gets hot
