Dont buy Harbor Freight jack
Old Mar 26, 2013 | 08:17 PM
  #31
TUCCI's Avatar
TUCCI
I don't know about the aluminum one your talking about, the HF lift I have has pedal, T handle, return spring mechanism etc. I've had the yellow HF jack for a couple years now and I love it....I moved the base plates out on the bolt and it made it even more stable than it was....Here it is holding up my bike when I did my ape installation:
I dont think the one you have is a current version....without looking at it who knows?
Old Mar 26, 2013 | 08:33 PM
  #32
BadBagger08's Avatar
BadBagger08
I went and checked out the HF locally and decided it wasn't the lift for me. I need a lift. I need to repair my tranny. They are quoting me 500-700.00 in labor and without a bike lift I just wouldn't be able to do it on my own.
I went and spent the $$ on the J&S lift should be here soon. I'm not going to trust my bike on a 119.00 lift. some of you peeps spend more on your grips, why scrimp on a product that holds up your 20-30,000.00 bike?
TUCCI: Not sure if its the camera but sure looks like that bolt is bending under the stress of holding your bike up, I would at least upgrade to grade 8 bolts if your going to lift it that away.
Old Mar 27, 2013 | 04:46 AM
  #33
Devo6684's Avatar
Devo6684
Originally Posted by lh4x4
I have the HF jack like in post #21 and 29. I use it on my touring bikes and it works great. I have the HF floor jack for 10 years now and it has done a great job.
I had a 840 lb Honda VTX1800 and a 940 lb Rune that the floor jack worked great on also.
I would trust the HF jacks on the $250,000 worth of bikes in my garage. Mostly because I know how to safely maintain, secure and operate them.
Some times it is the operator and not the equipment. Just saying.
+1. My yellow HF has worked great for my RK and now my Limited. I always use the locking mechanism and I also use ratchet straps - 1 on front of the frame fastened to front of jack and 1 on the back to keep it stable. I have even climbed on the bike with it jacked up to test my highway peg placement and it was plenty sturdy.
Old Mar 27, 2013 | 06:20 AM
  #34
RK Joy's Avatar
RK Joy
I have a HF low profile car jack only. I have had good luck with it but still use my Craftsman for the bike. I usually put a scissor jack under the tires to stabilize the bike and keep it from rocking while I wrench.
Old Apr 7, 2013 | 08:33 AM
  #35
Gunny68's Avatar
Gunny68
I bought the yellow HF jack a couple months ago. It worked ok at first as far as raising and lowering, though it lowers fast. The issue I had was rolling it around. The casters didn't want to swivel under the weight. Overall, it is wobbly and a bit scarry. Then a couple of weeks ago it began to not lift the bike well. The pump mechanism would stick and not reset each stroke.
I saw another member selling a used J&S for $325 and I picked it up last night. WHAT A DIFERENCE! It's sturdy, and rolls easily across the floor. I can swivel the bike around with one hand. As I find myself using a jack all the time, the higher quality jack is a must to me.
Old Apr 7, 2013 | 09:05 AM
  #36
Pete6114's Avatar
Pete6114
I got over 40k into my bike. Using a cheap jack just isn't in my best interest. J&S is the way to go!
Old Apr 7, 2013 | 10:34 AM
  #37
racklefratz's Avatar
racklefratz
You'll absolutely LOVE your J&S when it comes. They build 'em like a jack should be built - out of steel, and solid. Hope you also bought the accessory oil change ramp - it's great.
I saw that too. I don't know if it's bending or not, but either way, load-bearing hardware shouldn't be sticking out past the pivot point like that - it's an invitation to disaster, especially with low-grade fasteners. You definitely won't see anything like that on a J&S. When people spend megabucks on a motorcycle, then try to get by on the cheap with their jacks, I'm amazed. False economy, IMO. Chinese crap in general is, for that matter.
Old Jan 5, 2014 | 08:10 PM
  #38
desertwolf's Avatar
desertwolf
Originally Posted by RK Fan
It's an individual decision but mine works really well....
What is this lift?
Old Jan 5, 2014 | 08:22 PM
  #39
traildog's Avatar
traildog
Originally Posted by 1st 96 ultra
craftsmen of course , I still use my red craftsmen jack , when I work on my lawn mower , I use my J&S when I work on my $15000 motorcycle
BINGO! And, if you look around a bit, you'll find a used J&S. I bought my first for $200 sold it for $300 with the bike.
My second one cost me $250......
Old Jan 5, 2014 | 08:44 PM
  #40
$tonecold's Avatar
$tonecold
I guess they are just blind Tucci. They don't see the tab in the middle that is supporting the weight? I have used a HF yellow jack for seven years now without a problem and it still functions well. Admittedly it doesn't roll very well with the bike on it, but I don't usually want to move the jack with the bike on it.
