Engine Shake Riddle
Old Mar 25, 2013 | 10:47 PM
gdoc89's Avatar
gdoc89
Originally Posted by heritageblue2013
My 13 Softail is smooth at the light, while cruising, and smooth with the ladies.
My lady likes it at idle!!
Old Mar 25, 2013 | 11:32 PM
mkguitar's Avatar
mkguitar
as touched on above:
the counter balancing is a parasitic load on power, adding complexity to the lubrication, drive and bearings- any of which go wrong and pooch the motor.
the "rubbermount motor"- is actually the entire drivetrain, primary drive, clutch and tranny- the mount system adds the to overall height and will not fit the softail frame with out changing the entire concept of the styling.
The rubber mount system also robs some power- some forward motion is lost to the bushings.
as for comfort, some are fine with the solid mount buzzing along at speed- esp the pan/shovel/evo
but for all day operation the rubber mount bikes are more popular, the motor really only shakes at idle. stay off the front brake at a stop and the rider will notice it even less
mike
Old Mar 25, 2013 | 11:56 PM
Tom Hudson's Avatar
Tom Hudson
I think HD took a survey a few years back & they found this is what the owners wanted - they didn't want the balanced engine in the touring - My Ultra Classic is pretty smooth at speed, not as smooth as a GoldWing but what is - I think the Shake is just part of the Harley charm - not so sure a shake that bad is good for any engine but it is what it is - tom
Old Mar 26, 2013 | 02:08 AM
fxdxrider's Avatar
fxdxrider
The B engine came out a year after the standard (rubber mount) 88 engine because they had to design and build the counterbalanced system for it. The reason the softail motor is solid mounted is because it enabled the bike stylists to wrap the frame around the engine a lot closer than with a rubber mount system to give a "neater" more custom look. It makes less power but vibrates less at idle. It's not smoother once your feet are on the pegs.
Old Mar 29, 2013 | 08:30 AM
FL-kruzen's Avatar
FL-kruzen
Thanks for all the comments. I just always wondered why. All the jap and British bikes don't have the shakes so I just thought it was a Harley thing.
Old Mar 29, 2013 | 08:45 AM
decencyxdefied's Avatar
decencyxdefied
My fxst was smooth all the time
Old Mar 29, 2013 | 11:20 AM
sargek's Avatar
sargek
I like the shake and wouldn't want a "smooth" idling Harley. My EG is smooth at speed, which is all I care about. The ONLY thing I don't like about the rubber mounting is the fact the stupid oil filter is right on top of the front mount, but that's another story...
Old Mar 29, 2013 | 11:39 AM
Notgrownup's Avatar
Notgrownup
I used a loaner Heritage from the dealer last year and found out quickly at 70 mph what they meant.... it goes through the handlebars... I will stick with the rubber mounted for trips... i might buy a Softy for local rides or for the wife after a few years on the FXDP ...
Flufebunekilr
May 1, 2026 08:07 PM
DeluxeCruiser
Jul 28, 2014 06:29 PM
bigirn
Jul 13, 2012 01:55 PM
rdrunner
Oct 2, 2007 02:23 PM
HDF Tech
Exhaust System Topics
11
Jul 26, 2005 01:58 PM
