Front forks
Old Mar 30, 2013 | 01:32 PM
satman's Avatar
satman
Default Front forks
Anyone out there try the premium ride double front fork cartridge kit that the Moco sells? Been thinking about trying them - I have a 2012 RGC with Ohlins on the back. Ohlins really helped the rear suspension.
Old Mar 31, 2013 | 11:09 PM
satman's Avatar
satman
Bump - Seriously no one has tried them??
Old Mar 31, 2013 | 11:48 PM
Neil's Avatar
Neil
For less money you could put in the Progressive Monotube. Same idea and lots of people have ued those. I will be putting a set in my 02 in the next few weeks.
Old Mar 31, 2013 | 11:53 PM
The Q's Avatar
The Q
Monotubes all the way. I've run both stock height and now the lowered Monotubes.
Old Apr 1, 2013 | 05:40 AM
grbrown's Avatar
grbrown
Put 'premium ride cartridge kit' in Search above and you will get about 20 threads, so you are almost right! Seems very few have indeed tried them.
Old Apr 1, 2013 | 08:03 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Premimum Cartridges
Those are nothing more than a very simple non-adjustable cartridge that has no piston ting to control the piston bi-pass oil. These cartridges were installed into all fairing model 2002~2005 FL's (one side only). For what ever reason the end users of those models chose to remove the cartridge and put the other side with a damper rod like the non-fairing models of that era.
If you wished to do it the cheap way, find a pair of complete cartridges from that era, modify your existing fork tubes as per my movie featuring Amy, than install. You will need a fork oil tool & spring compressor. HD uses these crap cartridges in the XR1200 LA model forks but it is too costly to convert over.
These cartridges will perform poorly as all of the other 41mm suspension solutions currently available. Here is a XR1200 cartridge so you know what you are looking at (the one on the bottom only).
Larry64
EVO
11
Nov 5, 2018 11:09 PM
LouisM58
Feb 16, 2014 12:00 AM
Roni
May 20, 2013 07:48 PM
vasya100
May 23, 2011 10:17 PM
09DynaRyder
Mar 19, 2010 11:56 AM
