Does engine Chrome raise temp??
Old May 13, 2013 | 08:50 AM
  #31
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Originally Posted by drukanfu
Me no unnerstan....unless you were driving your boat ?
Speaking of driving your boat....are you say'in you were having sex from Key West ?
Hey pal, rain did it for free
Old May 13, 2013 | 09:03 AM
  #32
Expat1's Avatar
Expat1
Originally Posted by taconite
Lucky you were able to ride that bike under water to get the effect of immersion cooling. It must of been a wicked hot day in the Keys if the ambient air temp was close to 400 F and you couldn't get any convective cooling across the surface of the engine! No Delta T that day...
Newton's cooling law is a solution of the differential equation given by Fourier's law:
Where:
is the thermal energy in joules is the heat transfer coefficient (assumed independent of T here) (W/m2 K)
is the surface area of the heat being transferred (m2)
is the temperature of the object's surface and interior (since these are the same in this approximation)
is the temperature of the environment; i.e. the temperature suitably far from the surface is the time-dependent thermal gradient between environment and object
Why dont you say this formula gives you WATT units. It would have been a little easier to understand! This is the formula one uses to calculate the power of a kettle
Mawwk
Jun 19, 2016 09:10 AM
Tonto1515
Sep 21, 2011 12:28 PM
rustyruss
Jun 14, 2010 02:24 PM
wreckdiving
Mar 21, 2009 07:02 AM
testifer
Mar 6, 2008 08:42 PM
