Tssm ?
Old Apr 3, 2013 | 04:18 PM
NELS's Avatar
NELS
Unhappy Tssm ?
'10 RK Won't start with the fob present. Changed the battery and when that didn't work changed the fob to no avail. If I use the security code it starts fine. All wires and connections seem to be clean and tight. Any way beside going to the dealer or replacing the TSSM to diagnose ? Thanks for any help.
Old Apr 3, 2013 | 04:46 PM
KCFLHRC's Avatar
KCFLHRC
Could be a fuse for the TSSM, looking at the wiring diagram it is fused.
Old Apr 4, 2013 | 05:15 AM
NELS's Avatar
NELS
Thanks, didn't think about that. I'll check it but it did give me the same problem once and did start after multiple trys but could be corrision at the connection. Fingers crossed.
Old Apr 4, 2013 | 05:21 AM
broziff's Avatar
broziff
Did you just install the security or did you already have it? Just asking cause maybe you need to reset the tssm.
Old Apr 4, 2013 | 05:26 AM
NELS's Avatar
NELS
Bought the bike with it installed but, How do you resset the tssm?
Old Apr 4, 2013 | 05:31 AM
NELS's Avatar
NELS
Old Apr 4, 2013 | 05:36 AM
broziff's Avatar
broziff
https://www.box.com/s/a01de215ed6080294da4
Process takes 30 min to do on your own but if your install was factory you probubly dont need to remarry the tssm.
Old Apr 4, 2013 | 05:47 AM
NELS's Avatar
NELS
OK , Thanks. I don't think it has to re-learned as I have no trouble using the code to start it. Gonna check the fuse in a little while and will post if anything changes .
Old Apr 4, 2013 | 06:22 AM
NELS's Avatar
NELS
Here's an update: Just went and started the bike. No problem. I had ridden a few days ago and thought the battery sounded a little weak as in a kickback when cranking , like a bad compensator will do , so I put it on the trickle charger which showed a little low. The battery was replaced at the end of last year but I think it is not 100%. I'll have to do a load test on it and find out.
Bripac393
May 23, 2025 04:54 PM
rdbeard
Jun 9, 2014 06:23 AM
ghoticov
Apr 27, 2013 05:11 PM
nauzerlvr
Mar 25, 2013 06:15 PM
hdfun123
Mar 2, 2011 04:15 PM
