Inch pound Foot Pounds
Old Apr 4, 2013 | 04:27 PM
jeffreydsilver's Avatar
jeffreydsilver
For all you numb nuts out there - THERE ARE 12 INCHES IN A FOOT!
YES - it is that simple!
Old Apr 4, 2013 | 06:39 PM
1st 96 ultra's Avatar
1st 96 ultra
Originally Posted by Leftcoaster
No flaming here, but anyone using this forum very likely uses Google on a regular basis. Google is your friend and finding that answer is only a couple of clicks away.
That is why some may get flamed a bit for staring blankly at their torque wrench silently pondering how to convert in/lb to ft/lb and then posting their confusion on a forum.
ya beat me to it LOL
Old Apr 4, 2013 | 06:50 PM
Billyram's Avatar
Billyram
If you plan on working on your Harley you'll need both in lb and ft lb torque wrenches. And get good ones.
Billy
Old Apr 4, 2013 | 07:30 PM
golfblues's Avatar
golfblues
Lmao, you are as smart as a 5th grader.
Old Apr 4, 2013 | 07:43 PM
TUCCI's Avatar
TUCCI
Originally Posted by ohioflhs
Remember also that most wrenches are good down only to the 20% of full scale point. Don't want to use them below 20% of full scale.
Can you break that down a little more, explain the 20%.....I for one am interested.
Old Apr 4, 2013 | 08:18 PM
Lowcountry Joe's Avatar
Lowcountry Joe
With all due respect, apparently you have never seen a calibration sheet from Snap-on or from CDI (a Snap-On company). Quality wrenches, properly calibrated, are very accurate anywhere in their range.
Now if you run cheap Chinese ****, well, that's another story.
And for the OP...the quickest way to damage threads is to use a foot pound wrench for an inch pound application...and of course if the foot pound wrench is a cheap piece of **** you are almost guaranteed to ***** up your fastener.
Old Apr 4, 2013 | 09:36 PM
btsom's Avatar
btsom
It is reassuring that some in here know Jack.
Old Apr 4, 2013 | 10:28 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I've known Jack **** for some time. Even though my Wife swears I don't.
Old Apr 4, 2013 | 11:20 PM
2black1s's Avatar
2black1s
Originally Posted by Lowcountry Joe
With all due respect, apparently you have never seen a calibration sheet from Snap-on or from CDI (a Snap-On company). Quality wrenches, properly calibrated, are very accurate anywhere in their range...
Accuracy is less precise at lower settings regardless of the torque wrench quality. Typically the rated accuracy for wrenches is expressed from 20 to 100% of the full scale. Some higher-end wrenches may provide the accuracy standards for settings less than 20% of full scale, but many do not.
None of this is to say you can't use the wrench at these low settings, but with critical applications you do need to be aware of the compromised accuracy.
Here's an example of accuracy standards for a $550.00 Snap-On wrench with a range of 12.5 to 250 ft. lbs. You'll notice that it is less accurate at settings below 20% of the full scale.
The following is quoted from a Snap-On catalog...
Note:
The certification of accuracy provided per ASME and ISO Standards is 20% to 100% of full scale.
Torque Accuracy: 10% to 19% of full scale
ą4%CW, ą6%CCW
Torque Accuracy: 20% to 100% of full scale
ą2%CW, ą3%CCW
Torque Accuracy: 5% to 9% of full scale
ą8%CW, ą10%CCW
Old Apr 5, 2013 | 12:49 AM
vizcarmb's Avatar
vizcarmb
Metric system still rules
