Inch pound Foot Pounds
Old Apr 5, 2013 | 02:22 PM
  #31
ohioflhs's Avatar
ohioflhs
"With all due respect, apparently you have never seen a calibration sheet from Snap-on or from CDI (a Snap-On company). Quality wrenches, properly calibrated, are very accurate anywhere in their range.
Now if you run cheap Chinese ****, well, that's another story.
And for the OP...the quickest way to damage threads is to use a foot pound wrench for an inch pound application...and of course if the foot pound wrench is a cheap piece of **** you are almost guaranteed to ***** up your fastener. "
With all due respect, I don't care what the snap-on or craftsman cal certs say because most of the time they are out of tolerance when I receive them new from the mfr. I have cal'd thousands and thousands of torque wrenches and what I said is true.
Old Apr 5, 2013 | 02:45 PM
  #32
bohica48's Avatar
bohica48
Just another dummy here, but are the torque values specified in the manual for dry applications or based on some form of lubrication? I would think that thread lubrication would have an affect on torque values.
Old Apr 5, 2013 | 02:54 PM
  #33
aces25's Avatar
aces25
It's like using a butcher knife for surgery. Just buy the scalpel.
Old Apr 5, 2013 | 03:30 PM
  #34
Nitro NHRA's Avatar
Nitro NHRA
"And for the OP...the quickest way to damage threads is to use a foot pound wrench for an inch pound application...and of course if the foot pound wrench is a cheap piece of **** you are almost guaranteed to ***** up your fastener. "
This statement is BS.
The next time you have a wrench on your transducer click the wrench off in lbf.ft then switch the display to lbs.in. then do the math. If it don't equal the same amount then your equipment needs calibrated. Been in the torque and tension Biz for over 20 years. You name it I've worked on it. Improperly using a torque wrench will change the accuracy of the wrench itself, and most people don't know the proper way of using one. Example: If your wrench is laying around and is set at 50 lbf.ft, and you need 25 lbf.ft. So you set it to 25 and go and tighten your nut. I'll guarantee you that that the accuracy of the initial click would be 6-10% off of set value.
You should always click the wrench off several times after adjusting it, before using it. Put the square drive in the vise and click it off a few time's. This allows the spring in the wrench to settle to its set position. It will also give you a feel for how much force will be applied to the handle while tightening your bolts.
Always store your wrench in it's lowest setting.
Old Apr 5, 2013 | 05:58 PM
  #35
2black1s's Avatar
2black1s
Lubrication, and also the type of lubrication, has a big time effect! Just another variable in the torquing of fasteners and there are many. Unless otherwise specified, I will always assume a torque spec is for a lightly lubricated (like motor oil, or loctite where appropriate) fastener. Don't know if that's right but that's what I always do... If I'm using a torque wrench which is hardly ever - but that's a whole 'nuther discussion.
Old Apr 5, 2013 | 06:09 PM
  #36
RPS1981's Avatar
RPS1981
Originally Posted by leon anthony
try to do 20 inchpounds with a foot pound wrench
Bingo.
This is exactly why the conversion formulas, while interesting, are not very helpful.
Old Apr 5, 2013 | 06:47 PM
  #37
Billyram's Avatar
Billyram
Only the cheap wrenches vary more than a couple % from the lowest setting to the highest. I just grabbed my CDI in lb wrench that has a range of 30-150 in lbs in both directions. Clockwise is 30.14 = .5% 89.26 = .8% 151.48 = 1.0% Close enough for me. 10% or 20% throw it in the trash !
Billy
nivensid
Aug 5, 2011 05:17 AM
trozenhorse
Dec 1, 2009 02:05 PM
azhole
Dec 21, 2007 08:55 AM
MDodson
Apr 8, 2007 11:12 AM
HDRK01
Jul 31, 2006 04:31 PM
