ultra classic CVO 103 code issues
Old Apr 5, 2013 | 07:51 PM
pcarter79's Avatar
pcarter79
Stage II
Default ultra classic CVO 103 code issues
Strange problem, started and shut down and from then on check engine and red key light steady burn, it will start after 3 or 4 times and then stay running with both lights on.
I got home and tryed to pull a code but the only thing that came up after the diganostic flash was bus-er. and it would not go past that. Later that night I tryed it again and it went thru all sections and pulled 2 codes, U1255 pn-673480 serial data error and U 1300 pn-6722-04 low serial data , was able to clear the codes, lights went out and started fine ran good for 5 miles both lights came back on and then it started the whole problem again. Hung up with bus-er Any ideas, Thanks
Old Apr 5, 2013 | 08:15 PM
dawg's Avatar
dawg
Check the connection at the ECM and make sure it's seated good. Could be a connection elsewhere as well.
Old Apr 5, 2013 | 08:49 PM
2black1s's Avatar
2black1s
Each of the codes you retrieved (U1255 & U1300) and also the "BUS Er" indicate a problem with the serial data communication circuit.
Here's the possible causes for U1255...
  • Open battery fuse
  • Open battery circuit
  • Open battery ground
  • Open serial data circuit
  • TSM/TSSM/HFSM malfunction
  • Short to ground in power circuit
And U1300...
  • ECM malfunction
  • ECU malfunction
  • Short to voltage in serial data circuit
  • Radio malfunction
  • Open in serial data circuit
  • Speedometer malfunction
  • Tachometer malfunction
"BUS Er" indicates a lack of communication within the serial data system and the same potential causes apply.
The Electrical Diagnostic Manual has a troubleshooting sequence and process for this and many more electrical issues and is worth it's weight in gold.
Without having the manual handy to troubleshoot, about the only advice I could give is to check the battery fuse and the serial data circuit wiring. That circuit consists of the LGN/V wire that runs to each module (ECM, ABS, DLC, TSM/TSSM/HFSM, Radio, Tach, & Speedometer) and it's associated ground wire.
Old Apr 6, 2013 | 06:42 AM
pcarter79's Avatar
pcarter79
Stage II
thanks i will strat checking can i get the manual from harley?
Old Apr 6, 2013 | 03:21 PM
jus2anoyu's Avatar
jus2anoyu
I had a similar issue with my 06. I never use the off/run button on my controls. I always turn it off with the main switch below the handlebars. For some reason, I turned the engine off with the switch on the controls. Upon restart, the bike ran very poorly and those same lights were on. Just for ***** and giggles, I cycled the off/run switch several times, and everything was back to normal. Worth a try and doesn't cost a dime...
Old Aug 17, 2013 | 06:18 PM
superfxr's Avatar
superfxr
6th Gear
Default was problem fixed
Just checking to see if you fixed this problem
barrybrockway
Electrical/Lighting/Alarm
Apr 10, 2018 10:22 PM
Chinwig
Sep 24, 2016 05:31 PM
superfxr
Mar 25, 2014 06:03 PM
matthewthamm
Dec 30, 2008 06:18 PM
HDF Tech
General Topics/Tech Tips
Jun 27, 2005 08:18 PM
