Problems calculating MPG with Power Vision!
Old Apr 6, 2013 | 04:27 PM
WestTexasRanger's Avatar
WestTexasRanger
Default Problems calculating MPG with Power Vision!
My Power Vision is showing approximately 12 to 14 more Miles per Gallon than what I hand calculate.
I posted this on the Electrical/Ignition/Tuner/ECM/Fuel Injection Forum and had one post suggesting that I just need to update the Firmware on my unit, which I've done, but I haven't had a chance to go for a ride yet to see if that solved the problem.
Will the Firmware Update correct my problem or do I need to make some sort of adjustment to the Power Vision itself, to correct the MPG function?
Old Apr 6, 2013 | 04:58 PM
ColoSpgsMark's Avatar
ColoSpgsMark
You need to run a tank or 2 through it to set the correction factor for both your miles and miles per gallon. This can be done on the trip screen by just entering the actual miles and actual gallons when you fill up.
06flstn
The Dyno Room
Apr 23, 2017 04:10 PM
notimeleft
Feb 18, 2014 04:31 AM
WestTexasRanger
Apr 7, 2013 06:25 AM
PA SILVERBACK
May 23, 2009 01:44 AM
cutacroshorty
Sep 30, 2006 01:50 AM
