Rocker box gaskets
Old Apr 6, 2013 | 09:24 PM
Chopperbob's Avatar
Chopperbob
Default Rocker box gaskets
Well I found my lower rocker box on my Twinkie
Seeping a small amount and thought I would
Fix it. I bought the gaskets from comictec the uppers
Are easy but which way do the lowers go on
The are metal with some raised areas.
Old Apr 6, 2013 | 09:29 PM
QC's Avatar
QC
The lower one has a curved outline that matches the area on the head (look at picture- the area behind the back pushrod). Make sure the curved outline on the gasket covers that.
Old Apr 6, 2013 | 10:29 PM
Bingee's Avatar
Bingee
This should help.
Old Apr 6, 2013 | 11:05 PM
Chopperbob's Avatar
Chopperbob
Thanks I've got it now
Old Apr 6, 2013 | 11:08 PM
JetD's Avatar
JetD
+1 on Bingee:
The shop that built mine put the rear gasket on upside down creating a very small seep over time;
and prevented some oil flow in one of the orifices.... bummer! Thanks for ESP!
Old Apr 7, 2013 | 12:16 AM
Chopperbob's Avatar
Chopperbob
Ok I got the rear off and the prev owner used
A gasket that was marked on one side for front
Head flip it over and it says rear head. Well
The rear was installed upside down. Would
This cause my seepage and rocker box ticking
Old Apr 7, 2013 | 07:54 AM
batman4706's Avatar
batman4706
Good idea to change the breather pads while you're in there.
Old Apr 7, 2013 | 10:07 AM
Bingee's Avatar
Bingee
Yes on the seepage. Don't know about the ticking. But, when things aren't put together correctly, anything can happen. So when the oiling path in the rocker box is messed up I suppose it might. While you got it all open just check to make sure all bolts are tightened down. Don't make them tighter! Just check to make sure they're not loose. Also check to make there's nothing broken in there like a spring. It's rare that there ever is. But, if the last owner screwed up the gasket...well...you know.
Old Apr 7, 2013 | 06:07 PM
Chopperbob's Avatar
Chopperbob
Well it's back together and the seepage has stopped And taking seems to have a lesson but time will tell
Keithhu
Jul 15, 2017 09:53 PM
ihjonny
Jul 28, 2013 03:32 AM
arkieollie
Feb 26, 2008 12:15 PM
617south
Feb 8, 2008 11:48 AM
fatbob
Sep 17, 2007 11:49 PM
