flh tool list ?
Old Apr 13, 2013 | 06:45 PM
alberta's Avatar
alberta
Stage III
Default flh tool list ?
does any one out there know what wrench and torx sizes are common in a touring models tool kit? what does Harley sell in there kits? putting together a tool roll but want to avoid the stuff I don't need for an 06 e-glide standard, if you have a tool list it would be appreciated. thanks
Old Apr 13, 2013 | 07:11 PM
TWIN CAM 96's Avatar
TWIN CAM 96
If you have a manual that would tell you
Old Apr 13, 2013 | 08:04 PM
mkguitar's Avatar
mkguitar
the most important torx size is T27--- many new owners find out the hard way that a T25 will seem to fit, then strip out the head...
many of us go through and replace torx head machine screws with allens to reduce the number of tools required on the road.
H-D and Cruz both make little tool sets which have lesser quality tools, but all in one package.
I have the H-D set that came with my bike ( 09 FLHTC) augmented with some craftsman and snap on stuff.
The H-D sets show up on the classifieds from time to time, member NY2AZ has had some for sale.
Mike
Old Apr 13, 2013 | 08:09 PM
chinookman's Avatar
chinookman
I put my own together. Bought a decent combo wrench set up to 3/4 inch, Ratcheting wrench set, 1/4" drive socket set and a 3/8" drive socket set, A torx set to fit in the 1/4" drive socket set, a full set of allen wrenches, some zip ties and electrical tape. I think that is all. Probably missing some stuff. I got kind of a big tool bag. Hopefully I have enough to fix it if I break down.
Old Apr 13, 2013 | 08:14 PM
AlaskaAviator's Avatar
AlaskaAviator
Visa or Mastercard with a high limit.
Old Apr 13, 2013 | 09:27 PM
98Ultra's Avatar
98Ultra
What ever you use to work on the bike, throw one of them into a bag. If you end up with everything you might ever need, you have it made.
In other words. What ever you need to do a job or repair, put one in your tool kit.
Old Apr 13, 2013 | 09:36 PM
0ldhippie's Avatar
0ldhippie
I just carry a cruz Outback'r H13 f, 12' cresent, duct tape and tire kit. Anything more than that I have ama towing and a credit card.
Old Apr 13, 2013 | 10:22 PM
alberta's Avatar
alberta
Stage III
checked the manual nothing I can find on tool list in there
Old Apr 13, 2013 | 10:46 PM
Harleypingman's Avatar
Harleypingman
Use the search function and you will find plenty of info. Can't blame a guy for posting the same, detailed info multiple times. And, if you are serjous about finding an answer, you won't mind spending the time searching prior threads.
I use the Windzone HD-1 kit and and supplemented with additional zip ties and duct tape.
Good luck.
Carl
ericedelman's Avatar
ericedelman
Here's what I carry (2011 Ultra, but I had almost all the same stuff for my 2006 Ultra).
Sockets from 1/4" - 9/16", plus a spark plug socket, ratchet and an extension or two.
Hex bits from 1/4" - 3/8".
Torx bits from T15-T45 and a T27 which Harley really likes.
10mm open end wrench for the battery terminals
adjustable wrench
scewdrivers, or a screwdriver with multiple bits
hammer - mine has a steel face on one side and rubber on the other
12" strikable pry bar
zip ties, black electrical tape, duct tape
vise grips - 2 sizes
Suspension air pump for rear shocks.
An LED flashlight with AA batteries, extra batteries.
A few rags and a container of hand wipes.
A tube of blue loctite and a can of brake cleaner.
A company called Slime makes a motorcycle specific tire repair kit which comes with a 12 volt compressor. I have not used the repair kit, but the compressor is useful.
My last roadside repair was 3 years ago, the splined shaft that holds the shift levers snapped - I used the vise grips as a shifter to get to a dealer nearby. They had the part, but no mechanic, so the other tools were useful to change the part myself. Before that, it's been years since I got anywhere close to stranded and needed a roadside repair.
I probably use the tools more to help others than help myself, but it makes me feel better to know I have all this stuff in the saddle bag.
