Muffler - Strange Question
Old Apr 14, 2013 | 06:36 AM
Lilman's Avatar
Lilman
Default Muffler - Strange Question
Ok, I know this is weird but here goes.
'10 Ultra V&H Monster Oval mufflers.
Has anyone ever had a problem with the muffler rubber mounts squeaking at idle?
My right one does it, sometime, sounds like a bunch of baby birds chirping! Yes, I have already checked everything. Entire exhaust system is tight and the rubber itself is in normal condition. When it's squeaking, just a little finger pressure anywhere on the muffler stops it. One small shot of any lubricant right where the rubber meets steel takes care of it for about a week then, squeak, squeak......... Drives me friggin nuts!
I was at the Harley shop yesterday and asked one of the service guys about it. Naturally never heard of such a thing. All he could come up with was maybe a little road dirt or brake dust had gotten in there.
Going to take both of them off and clean / inspect everything this week. Just wanted to see if anyone else had ever had the same issue and what did you do about it.
Anyone have a part number for the rubber pieces? I may just replace them for giggles while it's apart...
TIA!
LilMan
Old Apr 14, 2013 | 06:43 AM
dansflhti's Avatar
dansflhti
It is quite common.After a year or so I think the rubber hardens.Just give them a squirt of Silicone lub,that should quiet them down.I usually remove mine a couple times a year and clean them up and regrease them.
Old Apr 14, 2013 | 06:54 AM
RPS1981's Avatar
RPS1981
Yes!
Shot a little... something... don't remember what it was... WD-40 maybe... onto the rubbing bushing where it contacts the brackets on the top of the mufflers to quiet it down. Never has happened again.
Old Apr 14, 2013 | 06:56 AM
Iceman24's Avatar
Iceman24
Yep...pretty common thing so I don't know why the HD shop was unaware. They get dry & I just rub some petroleum jelly on them & squeak gone...easy fix.
Old Apr 14, 2013 | 07:04 AM
Lilman's Avatar
Lilman
Thanks Guys! I'll take them off and clean. Then I have some industrial silicone grease that is almost everything proof I'll lube them up with.
Stiggy's Avatar
Stiggy
I used a dab of anti seize last year and they're still quiet.
Old Apr 14, 2013 | 11:28 AM
davey019's Avatar
davey019
Ya put some lube on them and it will be gone or buy a new rubber stop
Old Apr 14, 2013 | 11:32 AM
Texas Fat Boy's Avatar
Texas Fat Boy
They also have a tendency of slipping/vibrating out of the mount.
harkon
Exhaust System Topics
Jun 30, 2018 05:26 PM
odie-in-az
Jul 27, 2010 02:29 PM
bmorebhoy
Jun 18, 2010 06:16 AM
Master Gunny
Jul 4, 2009 03:34 PM
zoopman
May 11, 2007 04:30 AM
