Need advice
Old Apr 16, 2013 | 04:47 PM
Juice's Avatar
Juice
I would just use a pipe cutter and trim the amount and a dremel tool to cut the notch and remove the ring I just cut. Leave the wires in bars and Wrap the wires in tape to protect them. Get the new bars and sell them to recoup some of your hassle.
Old Apr 16, 2013 | 04:53 PM
hynsonx's Avatar
hynsonx
Default advice
Originally Posted by B00001
Could you trim that end of the bar, then re notch it for the TBW?
I could and thats probably not that hard to do but then my bars will be uneven.no one would really notice but i would know and I'm kinda ****.
Old Apr 16, 2013 | 04:54 PM
hynsonx's Avatar
hynsonx
Default advice
They want the old bars back.
Old Apr 16, 2013 | 05:15 PM
Ragtop's Avatar
Ragtop
I would think the installer would have noticed this before he finished up the job.
He could have test fit them, and found the problem early on...
When I did my bars, the first thing I did was test fit them before doing any of the final wiring.
I think part of this should be the responsibility of the installer, he should have caught this
early on during the install and called you about it before he kept working on them.
Old Apr 16, 2013 | 05:24 PM
hynsonx's Avatar
hynsonx
Default advice
So what your saying is that you installed the clutch perch,master cylinder and both grips before you ran any of you wiring?I looked at the bars and mesured the width before i gave them to him.
Old Apr 16, 2013 | 05:28 PM
1st 96 ultra's Avatar
1st 96 ultra
seems like your installer , being the expert should have noticed something was wrong but you bought them direct to save some money and the parts markup is what the dealer gets to help cover this kind of stuff which your installer did not get so I think there is enough blame to go around , but seems like he could help out to , good luck , keep us posted
jcd15
May 29, 2015 09:14 PM
hynsonx
Apr 25, 2013 10:04 PM
MrDickArmstrong
Jun 19, 2012 01:25 PM
IRready
Aug 27, 2008 07:32 PM
spaniardguy102
Aug 18, 2008 07:19 PM
