Need help! lowered front end problems
Old Apr 18, 2013 | 12:43 PM
bknewcomb's Avatar
bknewcomb
3rd Gear
Default Need help! lowered front end problems
I had an Arlen Ness front end lowering kit installed on my 2013 streetglide and now it feels like I have no shocks the smallest bumps feel like I have a flat tire. Any suggestions I had this installed in Tennessee and now I live in PCB and I cannot take the bike back to have it fixed. Any suggestions would be very much appreciated. I had it lowered to make it level after installing a "21 front wheel.
Old Apr 18, 2013 | 12:56 PM
mkguitar's Avatar
mkguitar
If you want to fix the ride quality, you'll have to tear it apart and start over...
with a lowering kit- ALL the suspension has to happen in less distance and in less time- so usually stronger springs are installed.
so the "cushion" becomes a jounce.
also your new front tire may have less sidewall, which makes for harder ride- the sidewall absorbs some bumps itself.
and finally your new wheel, tire and brake rotors may be heavier than the old set up- more weight which is "unsprung" makes for a harsh ride
a replacement spring should be "progressive wound" which means that the spring will first compress lightly, then harder the more it is compressed
Mike
Wertz83
Feb 4, 2016 08:08 PM
kingan936
Mar 26, 2015 01:31 PM
ChetMains
Jul 9, 2013 04:59 PM
Stag556
Mar 28, 2012 07:18 AM
B-EZ
Oct 14, 2009 10:35 AM
