Tour Pak Mounting???
Old Apr 22, 2013 | 11:22 AM
Frogprince's Avatar
Frogprince
I installed the quick detach kit on my 99 and had to drill new holes. Wasn't a big deal since one on the very end matched up and I used that to hold the plate while I drilled the four new holes.
Old Apr 22, 2013 | 12:19 PM
claytucc3's Avatar
claytucc3
The holes are in different locations. Just plug the old ones and drill the new ones. HD sells a hard insert for the saddle bag that you can use to cover any of the work that you do. I think they sell for around $70 Retail.
http://www.harley-davidson.com/store...pak-liner-kits
Old Apr 22, 2013 | 12:52 PM
Joker65's Avatar
Joker65
Originally Posted by Bigbird
Hope someone can spread some light on this. I have an 09 RG. I recently purchaced a Tour Pak from an 06 CVO Road King (no mounting hardware). I then got a quick detach mount for my 09 off of Ebay (aftermarket). The holes on my Tour Pak don't line up with the holes on the mount. Are the mounting holes on the pre 09 Tour Pak different than the 09 and up???
I recently purchased an aftermarket Tour-Pak that fits the pre-2009 models. I ordered the reinforcement plate for the bottom of the Pak,
and drilled the Tour-Pak holes to match those on the rack mount and plate. (P/N: 90755-09)
Mine sits back a little bit from the seat, but only a couple inches.
Now (if we ever get rid of this fkn snow) she will have more room to stretch out!
Worked well, and I have the quick-detach (aftermarket) rack from eBay.
Old Apr 22, 2013 | 02:57 PM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by Harleypingman
Yes, they are different due to frame change with'09.
Just use the tour pak rack as a template to drill new holes.
Carl
Yep ... Do what HPM said ... many have and it works ... on some you may need to shim with a few flat washers ... No big deal !!!
Old Dec 9, 2013 | 06:02 PM
Doogie11's Avatar
Doogie11
6th Gear
Have you had any issues with the aftermarket rack? Did you put anything in between the detachable mount and the tour pak? I'm doing this set up also. Well, little by little anyway with funds as they come.
ShrinerRider
Mar 31, 2014 02:21 PM
VINNIE JAMES
Jul 5, 2012 05:58 PM
John Schleifer
Mar 4, 2011 07:51 PM
OldTimer
Apr 7, 2010 09:10 AM
jb27
Mar 9, 2010 05:11 PM
