I finally bit the bullet and got an acc beanie. They were dot certified until about 2 years ago. Apparently they 'met' dot certification but did not 'exceed' dot so they lost the dot stamp. They are an interwoven mix of carbon fiber and kevlar. It's the lowest profile and lightest I have ever seen. They use to be in Florida, and they would custom fit them if you went to their store. When I ordered mine, it didn't fit right. I called and they said they could make it 'shaped' different if I would send it back. So I did. It's now a perfect fit. At 140 some odd dollars, it's the most expensive lid I've ever owned, but it's by far the most comfortable lid I've ever owned as well.....
I always thought that to be DOT approved, the padding inside had to be a minimum of 1.25 inches or something there abouts? That's what gives DOT helmets that mushroom head look but also the required DOT protection? I guess I was wrong?
As far as light and lowest profile goes. Neck and back pain are common for me because I wear a Helmet at work and usually has a set of NVGs attached to it. And a counter weight to the back or a large battery pack.
I also have to stick my head out into the wind while flying Aircraft and it bumps and jossels my neck. I like a lightweight, low profile helmet because it saves my neck in the wind and does not compress my head down when riding.
Why would you say something so stupid?
When someone takes the time and effort to share his experience and includes a VIDEO I think we should all say thank you!
Grow up!
Maybe he thought the guy was nutty as a fruitcake.
