Starter problem only when hot
Old Apr 24, 2013 | 06:06 AM
toothmansteveb's Avatar
toothmansteveb
Had the same problem on my 09. Replaced the stock starter with a new All ***** starter and no more problems. The new starters have a little more power than the OEM.
Old Apr 24, 2013 | 06:29 AM
SGLarry's Avatar
SGLarry
This may sound weird, but how's your battery? ....I was having similar hot start problems last year on my '09. It would sound like the starter gear was slipping. The battery was ok but was getting just a little slow. I put in a new battery and is hasn't happened since. I 've seen in other threads were others had the same issue. Just something you might want check...
Old Apr 24, 2013 | 06:32 AM
Notgrownup's Avatar
Notgrownup
Buddy of mine started to get this starter grind/kickback... SE COmpensator all is good.
Old Apr 24, 2013 | 06:34 AM
Notgrownup's Avatar
Notgrownup
That is the first thing HD did to mine with a high torque starter, new grounding strap, still had the grind...New stock compendator...still a grind, now i will have a Screaming Eagle installed in the next few weeks and we will see.
bbest71
Electrical/Lighting/Alarm
Oct 20, 2015 08:53 PM
scot210
May 29, 2014 10:08 PM
Jackie Paper
Dec 15, 2011 01:16 PM
ConRic72
May 15, 2010 09:18 AM
lowglide88
May 11, 2008 09:12 AM
