Shift stiff especially downshifting
Old Apr 25, 2013 | 10:13 PM
Headcockedsideways's Avatar
Headcockedsideways
Default Shift stiff especially downshifting
Started all of a sudden. Shifter is so stiff, sometimes have to like stomp on it to downshift. All fluids are at correct levels. Clutch cable adjusted tight.
Any suggestions where to start?
Thanks,
Jeff
Old Apr 25, 2013 | 11:10 PM
mkguitar's Avatar
mkguitar
primary chain tension ?
overly tight ?
easy to check that.
if that is the problem ( and check the shoe for wear through) then the Hayden M6 is a great retrofit for the evo.
also the clutch itself is adjusted through the round cover on the primary case- after which the clutch cable is adjusted for correct lever action.
first one, THEN the other.
this is important.
Mike
Old Apr 25, 2013 | 11:22 PM
stupid_rope's Avatar
stupid_rope
check your shift linkage
Old Apr 25, 2013 | 11:31 PM
Def Mute's Avatar
Def Mute
+1...
Start there, by disconnecting the linkage and see if the shifter shaft/bushings are bound up. If they are free, pop the top off the transmission and pull the shift drum out. Check the shift drum bearings, manually slide the shift forks, and check the shifting pawl (while the shift drum is removed from the transmission). After that, it's pulling the gear set out and checking the gears/bearings...
twistedcherokee
May 21, 2017 07:00 PM
01hdfxstd
General Topics/Tech Tips
Sep 7, 2015 11:46 PM
Siv24
Jun 5, 2014 01:55 PM
lagrato
Apr 4, 2010 07:50 AM
dwfan2
Apr 20, 2009 05:00 PM
