OK so lets say I install a Thundermax on my 2012 SG but I keep my stock ECM.
Now if I wanted to take the Thundermax ECM off and put the stock ECM back on would everything on the bike operate back to the original stock configuration?
I know that the Thundermax uses 18mm O2 sensors so if I went back to the stock ECM I would also go back to the stock header pipe and reinstall the 12mm O2 sensors.
So doing this would the bike be back to totally stock operation, would the odometer read the correct mileage for example?
